If its older than 15 years you have no problem .
If not and its already in australia you will not get it complied . If still in japan there is a place in sydney that have plates for 32's now .As you are in melbourne i couldnt tell you .
Evian can you please be specific what you're after?
A compliance plate is usually riveted to the engine bay of the car and not something you need a 'holder' for. Any car coming into Australia needs one of sorts - under SEVS you get a plate, whilst under the 15 year rule a plate with the local VIN is affixed to the car.
As wrxhoon said, there is one place in Sydney that now does R32 GTST SEVS compliance work. You'd need to contact them for a price.
Right! Anyone can private message me the details for the Sydney Compliance plate R32 ...
I'm still looking in importing one. So I don't have the car with me. Also I thought the 15 Year thing is over isn't it ? You can no longer bring 15 year old cars in without compliance..? Well please correct me if I got that wrong.
You can still bring 15y.o. cars in but it can finish anytime now .
If you want to bring a 32 give me a p.m. and can put you in touch with someone in japan to buy the car for you so you dont have to pay an extra $1000 to saomeone in australia as well .
Actually Evian if you read the thread it shows the full story. The Govt has proposed a change to the 15 year rule, but it has not been officially 'gazetted' yet (published). Until it is, the current rule continues to apply and you are still able to import cars under the 15 year rule.
Ring up an importing company and ask them, im sure they all have their hands on the most up to date info. Try www.prestigemotorsport.com.au
AFAIK, the 15 year old rule is still going, and as long as you can show proof of purchase before the rule change, you can still import your car.
Hey guys, still on topic, I am considering buying a late 89' model R32 GTS-T, its already here in the country. Can I still get 15 y.o compliance on the car? I know this costs ~$1200, is there anyone who knows a good place in Brisbane to do the job? Thanks very much for any help you can offer.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
