When initialisiting the SAFC and you go into the
etc -> Sensor Type -> Hotwire
Do you set both the "In" and "Out" sensors to the sensor number or just the "In". I set just the "In" and it was idling rough... Also in the "Car Select" when you choose 6 cylinders which day does the arrow point? Diagonal upright or downright?
https://www.sau.com.au/forums/topic/7103-safc-initialisation-questions/
400HP, by referring to the SAFC setup chart, if In/Out sensor numbers are different, the manual will give two numbers i.e. 2/4.
If only one number is given, in case of R33, set both In/Out the same numbers.
Good to hear that now ur SAFC is working fine :-)
Yeh I'm very happy about it. Just need to get it tuned a bit now.
On the manual it says the GTR is a HW-3 so I'm assuming that its just Hotwire with sensor number 3? But I guess this must be it cos when i set it any other way it almost stalls at idle.
Yeap, 3 is the sensor number which must be set into In & Out settings.
Unless you are doing a GT-R single airflow meter conversion, then In & Out would be different values. That's what I read in SAFC manual and they give an example on a GT-R n 300ZX I think...
Can i install a 2nd hand SAFC and safely run the car before having it tuned.....Does the SAFC have a default mode of operation where it makes no change to the airflow signal or does it remember the previous owners setting??
Where do most people put the unit, i have a r33, thinking about modifying the small holder benieth the climate control.
Any advice greatly appreciated
Yes thats exactly what I've done. All you need to do is "Initialise" the SAFC. Theres a setting for this. You then make sure it knows the car type, the number of inputs and outputs and just leave the correction at 0.
This means it wil read in Aiflow and feed it back to ECU as is without correction. Just make sure you initialise it.
Hey Guys, my installation drawing shows 6 wires,
red = power
Green = Rpm
Brown = Ground 1
Black = Ground 2
Yellow = Airflow out
White = Airflow In
On the Ecu drawing for the R33 it list a throttle signal.
Question
Is the Throttle signal needed, if so, which color wire is attached to it.....
Help needed asap as l am in the middle of the install..
Thankyou
I don't understand your problem. If you've managed to do all the other wires its exactly the same. Follow the ECU diagram and intercept the throttle with your SAFC wire.
I'm not sure if it will run without it. I assume if you've already wired the airflow in and out that the SAFC is expecting the throttle reading too.
my install guide didn't tell me ANY of the colours of the ECU wires.... it only had colours of the SAFC wires. From each ECU pin there should only be ONE wire.
So all you do is locate the pin.... see which wire is coming out the back of it.... and tap into that with the SAFC wire.
  • 2 months later...
  • 8 months later...
guys, help please.
im installing my new s-afc today. only problem is where the wiring diagram(ecu pinout) shows my rpm signal wire on the ecu, there is no wire in this spot??????????
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
