Hey all...
I have a HKS 2.8L STROKER CRANK up for sale...
CRANK IS BRAND NEW
Only removed from box for Picture purposes...You will also be able to Buy different Conrods + Pistons to suit the 2.8L crank...May be a cheaper than the Full Kit
Reason for Sale :: Change in Plans with the Bottom end of the car...
WANT : $5000 for the crank
I am also able to sell this whole kit as FULL HKS 2.8L KIT as i have:
****BRAND NEW HKS STAGE 3 PISTONS 87mm****
and
****BRAND NEW HKS STAGE 3 CONRODS To suit ****
I may be needing the pistons and rods...But the crank must be sold...
If anyone wants the FULL HKS 2.8L KIT Im after $9500 for it all....
Let me know
If anyone is interested
https://www.sau.com.au/forums/topic/71269-brand-new-hks-28l-crank/
im interested in the whole 2.8l kit, but not sure about the 9500 price tag
Hey there,
have a look at HKS site
It is as follows:
HKS CRANK : 4,442.45
HKS STAGE 3 PISTONS 22mm: 2,386.23
HKS STAGE 3 CONRODS: 2,513.16
total: $9341
On top of that pricing i paid Shipping + Tax
So if you wanted the same kit i have then you would be looking at around $11,000-12000 DELIVERED may be even more depends...
If your still not interested in that price Then you could always buy my crank then buy cheaper conrods + pistons to suit the 2.8l stroke...
Up to you...
Yeah you can put it in an RB20/25/26/30 block. 20 and 30 would need customs pistons tho.
So with the RB25 forgies and RB26 rods and RB25 head this crank would work without anyother mods?
and would it be worthwhile in a RB25?
Im not to sure i dont think that its that simple though..
But i will find out for you
  • 1 month later...
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
    • Yeah, Duncan is helping sell me back to Android devices. I've hated the whole Android head units due to their speed issues. Even in my old Hyundai Kona (2022 model), it behind the scenes was Android, and slow and shitty to start up. Once running wasn't bad, but still a good 15 to 30 seconds.
    • My roof rails are off atm on the E39 until the rust is fixed. I did find another little bit of surface rust under the rails when I took them off. As @soviet_merlin said I'd just leave them alone unless you're planning on ensuring they're properly sealed. I was on the fence about leaving them off as the delete is still a thing in BMW E39's but I feel like the car is missing something (er, it is, der) with them off and I'm looking forward to putting them back on.
