  • Replies 412
hmmm.... nahh.. too far out of the way!!! and tooo tempting!
do people know the BP+hungry jacks in Lakemba.. its on King georges rd... if you're coming down king georges rd from homebush direction, its just after punchbowl rd...
there should be a decent area for the meet? then its just straight down king georges to the second meet (almost)!
agreed mr r32! which is why i am suggesting the bp! or do you mean, too many cops would go by on king georges!?!?!
i would rather not meet at homebush, as as people will be parking all through there and it may be hard to figure out who is who... plus cops will be cruising through there with all the modified cars!!! AND i don't want tag alongs!
thats a VERY bad choice!!!!!!!!!!!!!!!
dont go there, always cops
better off meeting at a servo along princess hwy after tom ugly's bridge.
ye the bp is fine but im afraid i have no idea where that is :D
perhaps a mini hills area meet first? then i can follow u's to whereever that bp is
better off going further down king georges past the wooliles and moblie servo and turn right into roselands shopping centre and use the car park on the left
its big and shouldnt get much attention
cant miss it
theres a sign that say roselands shopping centre turn right at lights
and a massive sign thing that says CENTRO i think
the pic didn't show up!!! i'll jsut start a search myself!!!
silv.. are you actually coming?!  i don't really know where roselands is?  is it on the otherside of the road, when driving up from homebush?!
you know where the bp is that you said?????
bout bout 1km down the rd on your right!
ask wilb he should know
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
