  • Replies 51
Originally posted by DR GTR
But  look on the bright side. You will be cruising with us now Dave! woohoo!
I KNOW!!!!!!
That's all that matters. I'm not at Loz's mercy anymore........I can tell him that I actually don't like him & it doesn't matter because I never have to get a lift off him again!!!! :bahaha: :bahaha: :bahaha:
https://www.sau.com.au/forums/topic/7157-finally/page/2/#findComment-106040
Originally posted by cereal_jacques
I KNOW!!!!!!
The truth comes out.... :bahaha:
https://www.sau.com.au/forums/topic/7157-finally/page/2/#findComment-106044
Originally posted by red900ss
Hey Dave it's raining right now! Go on you know you want to! :burnout:
Dino....If it wasn't tucked into it's safe little garage right now, Sydneysiders would be viewing some of the hottest 4wd burnouts known to man.......
I think tonight might have to be it's christening in the wet......
https://www.sau.com.au/forums/topic/7157-finally/page/2/#findComment-106120
Originally posted by ONARUN
i'm just hibernating and saving my cash boys. i'll be back soon with an old school ride. don't ask which one cause i haven't decided yet but it'll be something....
...old:rolleyes:
Get one of these George!
Thay are old AND they rock! :P
Dave, just be mindful of the likley hood of trowelling your new car on it's 1st day. :uh-huh:
https://www.sau.com.au/forums/topic/7157-finally/page/2/#findComment-106126
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
