hey guys, I had my alternator replaced last year as the old one died. It's been working fine but I do have a few issues:
- when I start it in the morning the battery light on the dash NEVER comes on. When I crank it, it sits around 12.5V which is awfully low, it will go to the "normal" 13.5-14V once I've given it a bit of a rev. Surely I should have to do this?
- When I drive I notice that my voltage is about 0.5V less than when I started the trip, even less if I've been using my headlights.
- Recently when I've been braking my voltage drops to under 13V which I don't think is a good thing.
Any suggestions? I have a negative grounding kit on my battery and my battery is an Optima D34M (big deep cycle battery). I drive about an hour in the morning and night to work and about an hour after work...so my battery should be getting plenty of charge.
https://www.sau.com.au/forums/topic/71606-r32-alternator-issue/
Sounds like something is missing. I know with the bosch altenators if the light is not hooked up sometimes you could get the alt to start charging with lots of revs, but what a light does is help it pull in at idle revs. My R33 charges at 14.4 Volts at idle.
Did the alt you replaced with your old one have the same pin config? Sometimes they can be arse about face.
Cheers
Sumo
    • Hi GTSBoy, Excuse my ignorance but what does a "Bad" Knee point mean ?
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
