Hi all,
I'm buying an R34 Neo engine and bolting it into my R33 gtst and wanted to know about what to do ect.
The Neo comes with all sensors, manifolds, turbo, coilpacks, power steering pump and ecu but no loom. Can the R33 gtst loom be adapted? Will it fit the Neo ecu?
Do I leave the gearbox in the car and drop the engine in to it or do I take it out with the old rb25 and fit it up to the neo outside the engine bay?
I'll be keeping my air conditioner pump, is it possible to unbolt it and leave it in the engine bay saving me from having to re-gas it?
Is there anyone who has done this conversion who can give me some ideas as to what is involved? Is there anyone in Perth who is bored and will want to help out?
Go the SAU information machine..
Cheers,
Cam
ps - I tried a search but couldn't pull up much..
https://www.sau.com.au/forums/topic/71705-neo-into-r33/
well ur frist question was about the engine droping in. well when u take out ur other eninge make sure u put a stand under the gearbox so it doesnt drop. u will have to get under the car anyways to unblot the gearbox from the engine anyways...
about the wiring loom it should work with the standard one now but u might have to spend sum money to get it tuned. ur better off getin the r34 neo loom and ecu.
and fot the conditioner u might have to disconnect it bcoz the hoses will be in the way depends if u take off ur turbo etc from the right hand side of the engine so it doesnt get in the way. to re-gas ur bottle its only like $70. so in my case ill dsconnect the air conditioner hoses saves alot more time
ps u might need sum mates to help u out when unbolting the gearbox from the engine..
https://www.sau.com.au/forums/topic/71705-neo-into-r33/#findComment-1322490
Jet - thanks for the feedback.
I know I'll have to remove the gearbox support and drop it down, but is it easier to leave it in or take it out with the old engine?
So it sounds like the r33 wiring loom will fit the sensors on the Neo engine, just need to look at the plugs for the ecu I guess.
Aircon - I thought it'd probably get in the way...
As for roping in some mates to help out - I'll be definitely needing to do that! :)
https://www.sau.com.au/forums/topic/71705-neo-into-r33/#findComment-1322574
Ian - yup, just found that out. I've located a R33 and R34 engine manual. Handy in telling me that the r33 loom won't work with the r34 engine.. :)
Need to search for an R34 loom. If anyone knows where to get one, please let me know..
https://www.sau.com.au/forums/topic/71705-neo-into-r33/#findComment-1322619
I know it's not exactly the same but I've recently had a Neo fitted to my R31
We found it much easier to remove the RB30 with the gearbox attached to it, and to drop in the Neo with the RB25 gearbox attached to it as well. You do need lots of hands to guide it all in properly without smacking anything though :)
As far as the wiring loom goes, you need the Neo loom and computer there's no question about it.
How different are the looms?
The first thing the electrician said when he came to wire it was "Erm, phuk."
That was coming from a guy who's done a lot on R33 RB25's but had never touched a Neo before then.
Either way he got it running in a day so don't be discouraged :)
https://www.sau.com.au/forums/topic/71705-neo-into-r33/#findComment-1322673
Mark - thanks for the info. Sounds like I'll be pulling out the lot and aligning gearbox/motor outside of the car.
I've got the computer and all sensors so just need to chase down a loom - have checked the R33 plugs and there's no way it'll fit the Neo ecu, not even with a hammer :)
https://www.sau.com.au/forums/topic/71705-neo-into-r33/#findComment-1322678
You'd definetly find it much easier to bolt the gearbox and the engine together out of the car.
Do yourself the service of doing some tidying up in the engine bay whilst it's got no engine in it, that's one thing you learn with being part of an engine conversion :)
When we were doing mine we pulled the Neo out of the halfcut with the loom still on it (Had no reason to take it off), the only thing we did with it was feed it through the firewall for when the electrician went to wire it up, so I can't really offer much insight as to the connections on the engine itself sorry.
Just looking at the engines side by side you can see a few obvious differences. If you still have the RB25 originally from your R33 I'd plonk the engines side by side and just look at them & pick the differences, preferably with an R33 and an R34 service manual at your side :)
https://www.sau.com.au/forums/topic/71705-neo-into-r33/#findComment-1322779
Mark - There will be a bit of time in between removal and fitting so I'll be taking the time to sort out the engine bay. Think I'll be taking some pics and doing up a tutorial too.. Got the service manuals so hopefully that should make things better.. :)
https://www.sau.com.au/forums/topic/71705-neo-into-r33/#findComment-1322795
Righto - I think I've now been able to source a Neo loom, but was thinking that as I'm going to have to try to wire it into the R33 chassis loom anyway, maybe I should just keep the exisiting R33 looms and adapt them to the Neo engine.
Also I've got a Mines R33 computer and have been told that these are remap-able so perhaps I could retain that and save on trying to re-wire for the Neo computer. Can anyone substantiate that the Mines computer will be remap-able?
Ideas? Comments?
https://www.sau.com.au/forums/topic/71705-neo-into-r33/#findComment-1325219
  • 2 months later...
Have finally gotten the R33 engine and gearbox out and now have the engines side by side in the garage. There are some differences but most things seem the same.
Photos of what is discussed below are here: http://members.iinet.net.au/~nunn/Neo/
Differences I've found are:
1. The throttle bodies are very different. The throttle positions sensors are plugged differently and the Neo has a second butterfly on it for traction control. I solved this by swapping the R33 throttle body over to the Neo.
2. The plug for the idle control valve (I think that's what it is - Round cylinder held in by two philips head screws at the back of the intake plenum) is different between the two. I solved this by swapping the R33 valve over to the Neo.
3. Vaccum hosing at the back of the Neo plenum is alot more complex than the R33.
Differences I've heard are:
1. The injectors are different sizes - to be solved by using an AFC.
2. The crank angle sensor is wired differently - Does anyone know if this is true? It looks like I can swap them over, does anyone know if this is the case? Otherwise they are plugged the same so will plug in directly and should work if wired the same. I am swapping over an exhaust cam pulley this week so will post photos once I've taken the cas off.
Aside from what's mentioned above, everything looks like it'll plug straight back in. I've even been able to save draining the AC and power steering pumps by just unbolting the units and moving them to the side. They will bolt straight up to the Neo when it's in place.
If anyone has knowledge about the differences between the R33 and R34 crank angle sensors and if they are the same or can be swapped I'd really appreciate the input. :(
https://www.sau.com.au/forums/topic/71705-neo-into-r33/#findComment-1443204
The s1 CAS is different from the NEO cas though i think the s2 is the same.
Problem is that the keyway is different meaning you cant fit a series 1 cas to the neo engine without modding the cam/cas. EDIT, just looked at the picks. You have a series 2 engine there so you may be able to fit the CAS.
Based on what you have said above i take it your keeping the r33 loom and ecu? Biggest problem i can see is you will lose the constantly variable inlet cam timing of the neo and have it replaced by the on/off r33 vct if it works at all. And that would be a damn shame.
https://www.sau.com.au/forums/topic/71705-neo-into-r33/#findComment-1449718
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
