Hehe - yep, heading to the dyno for that first memorable 'flame on' run :D
That's Rob directing traffic - and I think that's me walking away (they look like my shoes).
James G and Shan are in the background - but their fuzzy faces make it look like they've just watched the 'Ring' video :devil:
https://www.sau.com.au/forums/topic/71721-hi/page/2/#findComment-1324535
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
