Hi all,
I recently went to an electronics and computers expo in Sydney called Cebit (anyone else go?) and I saw a stand for an Aussie company called Voxson (www.voxson.com.au). They had a car MP3 player on show which also played CDs. The killer bit about it was the price - $259 - $299. It's going to be released in the next 2 or 3 weeks apparently.
Now, every other MP3 player I've seen for cars has been well over $500, some even over $1000. So, is this some sort of wonder head unit or am I missing something vital here. I really can't see how these other units can be so much more expensive.
Cheers,
Mic
BTW there's no info on the web page yet, it'll be up soon they said.
https://www.sau.com.au/forums/topic/719-mp3-players/
if i remember correctly, voxson used to be a shitty b-grade electronics company that made crap stuff that you would buy if you knew no better.
THATS if i remember correctly - which is highly improbable.
that is pretty cheap too, i was looking at a nice kenwood unit for about $900/
https://www.sau.com.au/forums/topic/719-mp3-players/#findComment-16326
I've never even heard of them. I suppose I'll be a guinea pig and try it out. I'll tell everyone here what it's like so they can either get one or be warned about it.
What was the model of the Kenwood you were looking at? I'd like to compare features when this one does come out.
https://www.sau.com.au/forums/topic/719-mp3-players/#findComment-16340
Voxson used to make discmans and stuff like that.
They distributed out of Brisbane.
Cheap no frills stuff. Pretty good quality but I haven't seen anything from them for a year or so.
It could be something to make them a big name, or maybe there just tryin to make money by jumping on the bandwagon. I spose it doesn't matter too much at that price though?
https://www.sau.com.au/forums/topic/719-mp3-players/#findComment-17423
Go the AIWA CDC-MP32!!! Wholesome Sony goodness (one up from shit) for $400 bucks. The Voxson one sounds like the CD-MP3 players you find at Northrocks Markets... ahh back in the day when i used to live in syd (like feb '02)... they do the job but skip like crazy, and they only play selected formats (VBR etc) stored in specific file structures.
My Headunit
https://www.sau.com.au/forums/topic/719-mp3-players/#findComment-17474
Personally I like the highend JVC MP3 unit, the Alpine is quite nice and the sound quality is comparable if not slightly better than the JVC, but it costs a lot more. Well over $1k everywhere I have seen.
I did see a kenwood 9020R MP3 headunit in Brisbane car sound today and it looks really shmick, and I generally don't like kenwood gear so that is high praise. No idea what it sounds like though.
https://www.sau.com.au/forums/topic/719-mp3-players/#findComment-22616
Guest Krystian_w
Hmm...
There's also the MP Zoo, don't know how it works exactly but it actually plugs into a Hard disk and plays MP3's straight off it. That means you can fit a couple of hundred CD's worth of music on the HDD...
Don't know much about stereo's but thought you might want to take a look...
If it helps I saw it at Brisbane Car Sound for about $800
https://www.sau.com.au/forums/topic/719-mp3-players/#findComment-25203
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
