Well if you're goin over some bumpy roads with a hard drive reading away, you're looking at best shortening the HDD's life substantially (I'm talkin about the standard ones used on PC's not the ones used in black boxes and standalone machinery they're a completely fdifferent piece of hardware and much much much more expensive)... at worst... instant sector damage by the head.
Usually when one dies it goes Click Burrrrrrrrrrr Click Buuurrrrrrrrrrr Click Burrrrrrrrrrr.... that's the head trying to find the first read position, and not being able to move up to the track because its been bumped.
I reckon MP3 CD players are much better on the long run, and much more economical.
And yes... the AIWA's still goin strong. Jus found out why one particular cd was skipping (none of my others do), coz it was a shitty quality CD... hehe another thing to watch out for on these things I guess.
https://www.sau.com.au/forums/topic/719-mp3-players/page/2/#findComment-25547
Maybe, but it wouldn't take long to buffer a whole MP3, so it would have to be really bad luck for it to buffer the wrong section of the disc because of a bump.
Besides, it will only go to the buffer in the situation where you go over a bump and it can't read for that split second, otherwise it would go straight from the CD. If you go over bumps when it is reading into the buffer and then go over more bumps at exactly the same moment in the song when you're playing it back, you most likely are driving off road and should be worried about your bodykit, not whether your song is skipping or not :P Basically, I don't think skipping would be much of an issue with MP3s.
https://www.sau.com.au/forums/topic/719-mp3-players/page/2/#findComment-26202
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
