Originally posted by akeenan
*** id like to take a minute and remember my old trust exhaust ...full 4 inch pipe with the good old 5 inch tip id belted out 108 db ...that lasted about 1 month :mad:    ****
thankyou.
Akeenan, i know this is kinda off the subject, but have a R33 GTS-T and just ordered a Trust Power Extreme II turbo back with a 3.7" pipe... it comes with a baffle that sits in the back box, but now i'm worried that it will be EXTREMELY loud... i live in a high residential area with lots of old folk who may become scared... is that what you had? Any baffle? :eek:
https://www.sau.com.au/forums/topic/7194-epa/page/3/#findComment-114890
  • Replies 64
Oh dear. The EPA and the elderly are certainly going to be unhappy. Is it unbearably loud? why did you take it off your car? You had a cat back didn't you?
I've ordered a turbo back, with cat replacement pipe (yeah yeah i know i shouldn't :uh-huh: ).... this will surely only be louder?
-marcus
https://www.sau.com.au/forums/topic/7194-epa/page/3/#findComment-115162
my car got complianced with that left on it...i wanted it left on so the place i got it done at just said ok....they knew it was illegal, but they didnt seem to care....
anyhow i got busted with it about 1 month later so we took it back to the joint and they replaced it for free with something legal....ive got no idea what it is all i know is that it is only 81db now and its got a 3 inch from the cat and a 3 inch tip...its all stainless steel. They said that my current exhaust is 100 times better than the other one but I would trade anyday!! however I would only get busted again...:mad:
and the dudes kept it and that was the last i saw of it
https://www.sau.com.au/forums/topic/7194-epa/page/3/#findComment-115168
  • 3 weeks later...
So i've just got my exhaust... only the cat back section at the moment; the front pipe is on its way.
It is a 4" TRUST Power Evolution, basically straight through all the way (there is a pic on the last page i think). It is loud. Witout the baffle i couldn't drive around; it was so bloody noisy. Has an awesome note though; without the baffle sounded like a racer.
With the baffle in (after 1 day) it is not too bad, but will still be a fair bit above the legal limit i'd guess... Akeenan, must be the same one you had. Posted some pics too
-m
https://www.sau.com.au/forums/topic/7194-epa/page/3/#findComment-129137
I received an EPA notice in the mail back in October for excessive noise.
Someone else was driving my car when they passed a copy car who had pulled someone else over. My car pulled into a driveway a couple houses down as this was his destination.
2 weeks later, I received the notice and had 30 days to have the car tested for sound. Somehow, my car had to come in at less than 90db at 4200rpm.....
How did a car like mine pass I hear you ask??? It's a long story but let me tell you that a dead stock R33 GTR including exhaust reads at 89.2 db and not all Midnight purple R33 GTRs are the same as mine :P
Oh and BTW, they don't give you certificates with smiley faces and passes to stick to your boot anymore. I don't even know where I put my copy of the statement which I sent to the EPA.
https://www.sau.com.au/forums/topic/7194-epa/page/3/#findComment-129600
Turtle, it is a bit low, but i have no problems on speed bumps so far coz my car is stock ride / stock wheels.
Leewah, hopefully i won't have to visit the EPA with the baffle in, but if i do i'd better find a friend with a silver series 1 GTS-t :P
https://www.sau.com.au/forums/topic/7194-epa/page/3/#findComment-130021
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
