Hey guys....i need some info about rebuilding engines.
Issue 1:
Recently I spoke to my mechanic about my broken RB20 engine in my R32 GTS4-T. As a GTS4 Rb20 is very hard 2 come by in melb at the moment (front diff, different sump and dont wanna change the sumps either) he suggested a rebuild. He said all up i'm looking at 2 grand.
Firstly...how's that price wise?
Secondly...he said something about not "thrashing it" for at least a month....and drive it "normally" (as in how my Dad drives @ low revs). Does that sound right?
Issue 2:
I also spoke to him about my R32 GTR.....same scenario. Engines gone, and he wants $2000 to rebuild it, and again, drive "normally" for at least a month.
Any help would be appreciated
Thanx.
Ali.
https://www.sau.com.au/forums/topic/71957-rebuilding-rbs/
im sure a more experienced person will have a better answer, but i would say the 'driving normally' would be the bedding in period for the new parts in the engine ie. let all those shiny new bits get accquaited with the oldies in the engine so they all get along..
id you just throw those shinies in there and rev it out they wont be very happy. bedding in pretty much is just letting all the new parts ease in and get all the straight cut and little ridgid bit off so they settle into the engine and stay settled in the right spot.
s.
https://www.sau.com.au/forums/topic/71957-rebuilding-rbs/#findComment-1326546
Issue 1:
Issue 2:
Thanx.
Ali.
To remove, repair and replace an RB20DET 4wd for $2K is amazing, take it. I wouldn't do it for less than $4K.
To remove, repair and replace an RB26DETT for $2K is amazing, take it. I wouldn't do it for less than $5K.
Do a search on running in engines, there is plenty on it.:D
https://www.sau.com.au/forums/topic/71957-rebuilding-rbs/#findComment-1326571
Issue 1:
Issue 2:
Thanx.
Ali.
if you are looking for a source of engines, check out this place:
Performance Jap Specialist
4B merri court,
campbellfield
VIC
(03) 9357 0658
they guy who runs it is Prassana
he is a great guy and has heaps of engines there (not sure if your particulr one, but it only takes one phone call)
cheers,
Warren.
https://www.sau.com.au/forums/topic/71957-rebuilding-rbs/#findComment-1326835
THanks heaps warren! Prasanna has a GTS4 engine......he wants $1350 for it with 2 months warranty on startup, plus I have to pay my mechanic 500 dollars labour to fit and remove, all up costs me $1850, and i can't be bothered running in the engine as I'm selling......so im very happy.
Cheers.
https://www.sau.com.au/forums/topic/71957-rebuilding-rbs/#findComment-1326854
Cheers.
all i can say is prassana is a legend - a genuine bloke. not often you find this with import parts salesperson...
https://www.sau.com.au/forums/topic/71957-rebuilding-rbs/#findComment-1327117
