As stated, i have a full haltech e6x ecu for sale. It comes with
coolant temp sensor,
trottle position sensor,
air temp sensor,
3 bar MAP sensor (extra!)
ignition module and
wiring loom and i
nstructions.
This unit also has a boost control function if the haltech boost solenoid is used( can be bought for 98 I think)
I am selling as I do not know how to install it myself and do not want to pay to have it installed.
Alternatively, if someone from Adelaide is willing to help me with the installation. i will gladly keep it.
This unit is bought new for $1500
The HALTECH E6X is a powerful "real-time" programmable fuel injection and ignition system computer designed to control most ignition type engines. Whether 1-6, 8, 10 or 12 cylinders, 1-2 rotors, naturally aspirated, turbocharged or supercharged, the HALTECH E6X can control it.
The E6X System optimises engine performance through the following capabilities:
Ignition timing control
Fuel control
Idle speed control
Closed loop
The E6X is much more than a programmable fuel injection computer - it provides logging of engine data and allows access in real time to maximise performance and trouble-shoot problems in a vehicle while running.
Typical Applications:
Control of fuel injection on modified engines
Conversion from carburetion to fuel injection
Race and rally applications of all description
Design and development purposes
Educational use by universities and technical colleges
Original equipment in cars and motorcycles.
The patented HALTECH system of programming virtually eliminates the input of numbers. You simply manipulate bar graphs by pressing arrows keys on the attached PC running Haltech Programming software. Manipulating the bars allows you to increase or decrease the amount of fuel delivered or ignition advance at that particular RPM and load point. The process is repeated for all load points in each rpm range.
Ignition timing is precisely mapped through the RPM range so that the exact timing required to obtain optimum performance is applied in every RPM and load range.
For those interested, I will be willing to let it go cheap at 1200.
https://www.sau.com.au/forums/topic/72017-haltech-e6x-for-sale/
Hi daniel
the haltech e6x system is a great unit,you must have relised what work and exspence was involved when you bought it.
I am interested in buying haltech but i don't care if it is e6k or e6x.would you sell the ecu and loom only or do you want to sell complete?
thanks stuart
Hi daniel
thanks stuart
pm sent
  • 1 month later...
Hi danial
would you be interested in a swap?
all your haltech gear for my greddy e-01 boost controller and apexi safc11 fuel control unit,both only 6 months old and in excelent condition,every thing supplied except for stands.
thanks stuart
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
