after 3 years and much money, we ended up moving north not south, so now i need a 4WD.
1993 R32 skyline Gts-t. 120,000km RB20, Manual
BN Sports Bodykit. Vertex front bar
Engine fully rebuilt at 115,000km
GTR cams
GTR injectors
GTR oil pump
GTR water pump
timing belt and idler bearings replaced, aswell as 100K service completed
Bosch 044 fuel pump
RB25 turbo
Tein HA coilovers
Tein adjustable castor arms (front)
1.5way LSD
4 puck clutch
Knight sports strut brace
Custom twin pipe, front pipe (CES stylee)
Full stainless mandrel 3" exhaust
HKS Pod filter
Z32 AFM
Orange neons
Orange interior inserts, and boots
Custom FMIC 600x300
A/C changed over and working well
Remapped ECU
Apexi turbo timer
Blitz boost gauge and Greddy pillar mount
Tomei Steering wheel and boss kit
RWC and QLD rego till 15/08
$16,000
Mackay QLD
There is a dent in the LHR (pics) some drunk A$$hole kicked it. Quoted $300 to repair.
Pics:
My picture gallery (more pics)
https://www.sau.com.au/forums/topic/72448-1993-r32-gts-t-16000/
mate ill seriously buy the car off you. this 32 looks bloody nice! it wouldnt take much for me to get to Mackay. Have you got the reciepts of the engine rebuild on you? if not would you be able to supply me wit a compression and leaks test at all?? You can contact me on my mobile (0408688563) cheers mate...
Hi.
I am a TQ mechanic my old man owns a w'shop, all the work was done there. I have the receipts for the head work, crank and conrod checks ect. aswell as the receipt for all of the parts.
Car runs great, sounds awsome (will get vid).
only prob is that it doesn't like first starts, low idle ect. but perfect when it warms up. I am gonna check out my AAC again tomorrow just to make sure it is working properly, but i think it could be in the tuning (440cc inj and Z32 MAF) as they didn't do a cold start tune/test
i also have a Profec A and a HKS glove box insert thingy, that you put gauges and stuff in if you want them too.
yeah, my car does the same thing when first starts, i have heard that it might have something to do wit the aftermarket bov or the earth wire on the fuel pump. anyway ALL sounds great mate! seriously give me a ring (after 5pm weekdays as that is when i finish work) so we can talk about this and get something sorted. cheers mate.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
