  • Replies 44
I have a REALLY cheap 89 GTR, in IMMACULATE cond... wait wait, no, in TERRIBLE condition! I still think its a good way to go though. I had it on the road with 12months rego for $17,000. $1000 will go into exhaust and springs(got defected). $1,500 into rims. so for under $20,000 the car is in pretty good shape and looking pretty good.
If you can be bothered putting some effort into these cars, they are a good buy. Put a few more K's into the body work and other minor issues and I will have a good reliable car with plenty of power and handling.
I think its an excellent under $25k option, you get a great looking and great performing ride... you just have to understand that you need to pick it up for about $6k less than what you want to spend.
https://www.sau.com.au/forums/topic/72488-89-gtrs/#findComment-1334987
guys lets not bagg all 89 gtr buyers, some of them eg my dads and the ones he has bought in have been in imaculate condition and has had alot of offers to sell his, but i do have to agree most of them are crap and whoever buys shit deserves shit,
end rant
cyas
https://www.sau.com.au/forums/topic/72488-89-gtrs/#findComment-1334994
Agreed.  Most 89 GTR buyers are trying to make a buck out of the ignorant!
However, I'm in the 1% of buyers that actually bought my 89 GTR for me.
thats correct see this is what most people are missing, if you want the car for yourself then you want it to be good but most of them are buying pieces of sh*t and then giving everyone else a bad name for 89 gtr's :birdie:
cyas
https://www.sau.com.au/forums/topic/72488-89-gtrs/#findComment-1335062
I'm glad to be in that 1% aswell, I think it will be awhile before I changed it.
https://www.sau.com.au/forums/topic/72488-89-gtrs/#findComment-1335145
agree with the other guys who bought the 89 GTR to keep. I will be keeping mine (unless I can afford an R34 - HA HA HA!). I'm very impressed with mine - the engineer that did the report wanted to buy it on the spot! he has even rang me twice wanting to buy it :D good buy - hell yeah! much cheaper and on par with (and better in most cases) than the other GTR's that were available before the 15yr rule...
https://www.sau.com.au/forums/topic/72488-89-gtrs/#findComment-1335186
We check and do an inspection report on quite a few that come into WA when the clients pick them up from the wharf.
On the average, they aren't bad but certainly haven't seen any immaculate examples for a while. All have compression/cylinder leakage tests as part of the inspection of which most are reasonable, a few very good and the rest seem to magically appear in the local papers for sale as immaculate shortly after we give them the bad news about there lack of engine life....
Read into that what you will. :D
People forget that they are a 15 year old, race based, usually owned by 3 or more drift/race wannabes and when they won't pass a Jap roadworthy are then sold overseas.
I HAVE seen a couple of really good ones, one of which I since sold on, but on an average you get what you pay for.
The japs are not stupid, they recognise an immaculate low km genuine example is worth far more than some shitter and the auction prices will reflect the good ones.
Cheers
Ken
https://www.sau.com.au/forums/topic/72488-89-gtrs/#findComment-1335251
I'm inclinded to believe mine fit the immaculate bracket. when we changed the clutch, it was the original unissa plate, that was simply warn from 90,000km. no feathering of the material, no broken springs, or smashed/bent spring housings and the flywheel had no cracks / gouge marks.
my mate who assisted in changing it worked for a brake and clutch place and said it was akin to something that was driven by a grandpa! based on the service history stickers and cam belt change, I wouldn't be surprised if the KM's are accurate.
Thats not really the point though - I think my GTR is great, I was lucky enough to buy it BEFORE people started thinking 15yr rule and am very happy with it :D
Anyway - if someone does sell their 89' for 30k, so what? I've seen then as low as 20k on carsales...
https://www.sau.com.au/forums/topic/72488-89-gtrs/#findComment-1335280
And more defense to us 89 GTR boyz... are we expected to follow the Mum attitude that a car should only be measured by how old it is... should I therefore be driving a 2004 lancer? Looks/Performance/Ride/Resell are all in my favour in the GTR. I think they are tops.
https://www.sau.com.au/forums/topic/72488-89-gtrs/#findComment-1335325
here is the only imacc one i have seen which my dad has this is how it came off the ship, most i have seen have been battered, we also get all ours personally inspected over there.
i am with gtrken were as most people have for got that most of the 89 gtr's were race cars
cyas
https://www.sau.com.au/forums/topic/72488-89-gtrs/#findComment-1335329
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
