Well yesterday was the first day of full wet weather driving for me in my car since ive had it. (Almost 3mths)
I think in the future i might just walk/ride to work (5km).
Driving my old car i knew the limits of how hard i could push before wheels would slide and brakes would lockup. In this car (R33 GTS-T) I dont.
* 90 Degree corners are near impossible under any accelleration.
* My mats get dirty
* Pedals are slippery and squeaky (can anyone recommend a good set of legal pedals for rubber soled shoes?)
On a good note, i cant use turbo or drive fast so im saving heaps of fuel.
:D
https://www.sau.com.au/forums/topic/7254-wet-weather/
yeh in my car you may as well be driving on ice if it comes on boost. off boost it's fine though :D You just gotta know to expect the odd step-out when going round corner's etc... and be prepared for it :)
on a side note I'm really glad the rain's arrived so that the bushfires can be put out. I'm sure the people who almost lost their homes are very thankful as well :) very good news :)
https://www.sau.com.au/forums/topic/7254-wet-weather/#findComment-106769
no offence meant but...
don't you think that you might be over reacting there. well, it's either that or you can't drive:rolleyes:
i found wet wether driving to be one of the more exciting things about owning a rwd. sure it's dangerous and you can slide out easy but it's damned fun
https://www.sau.com.au/forums/topic/7254-wet-weather/#findComment-106777
Im in both boats for this...
Jumping for a N/A car into a turbo RWD is so much different.
The driving styles are totally different... Usually u would have to
give it some gas around the corners in the N/A so not knowing
what to expect in the sky you would do the same..give it some
gas...heehhea. i bet u got a big fright benm not expecting it..
and yes it is fun in wet.. u get to know u'r tyre limits and how
you car reacts once traction breaks loose...
https://www.sau.com.au/forums/topic/7254-wet-weather/#findComment-106799
Exactly....
I've gone from a N/A 50kw FWD car to a Turbo 192rwkw RWD Car.
The last time their was a light shower of rain (enuff to wet the roads but not enuff for wipers) it brought all the dirt and oil to the surface and some 90 degree corners i literally slid out just turning them (w/o accelleration).
I'd love to go to a track day even just to do 5-10 laps so i can work out the limits of the steering. My old FWD car as u all would expect wasn't the best at cornering so im very cautious with the skyline.
:burnout:
https://www.sau.com.au/forums/topic/7254-wet-weather/#findComment-106801
etc etc
exactly driving in the wet is fine unless your a bad driver...
???? im confused, how do you drive in the wet ?? sorry im confused.
https://www.sau.com.au/forums/topic/7254-wet-weather/#findComment-107005
During the rain i switched from the Skyline to a gutless BMW 318. lots different. you can floor it and reef it around corners (in a way that would write off your skyline) and it still wouldn't unstick. its so much fun doing it in the Line' tho. Especially trying to perfect your wet road launching technique
One other thing i've noticed: Why do people seem to tailgate even more in the wet??? it seems like the rain is a signal for every brick-headed tailgater to come out for a drive (just stay off my ass!):shake:
https://www.sau.com.au/forums/topic/7254-wet-weather/#findComment-107534
DON91E i think they referring to u buddy!
ease up!
hahahahah:D
https://www.sau.com.au/forums/topic/7254-wet-weather/#findComment-107693
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
