89 Nissan Laurel
Rb20det 5 speed
white / blue pearl
Engine:
Rb20det
3" stainless cat back exhaust
3" mild steal double dump off turbo to cat
Trust Front mount intercooler
HKS mushroom POD
OS Geiken Twin Plate clutch and lightened Flywheel
Exterior:
4/5 stud 16" mesh wheels
Wing deleted
Sunroof
frong guards rolled
Interior:
Shift knob
Aftermarket handbrake lever thingy!
Boost and water temp guage
Pioneer Cd player and speakers
Handling:
GAB rear lowered suspension (damper adjustable)
Lowered front suspension
new polyurethane sway bar bushes
Registered and 107 _ _ _ klms on it.
NEW TIMING BELT DONE 16/09/05
$12 000 with rwc and 6 months rego as of this week. Please note now has a stock front bar to pass roadworthy.
0401 669 900 [email protected]
Pics coming shortly.
Cheers
Jayson
Edited by Mase
https://www.sau.com.au/forums/topic/72710-fs-nissan-laurel-rb20det-5-spd/
  • 1 month later...
Will sell with the 18's instead for an extra grand. These wheels clear skyline callipers without any spacers and allow a disc and calliper upgrade without having to go full five stud. New tyres on the front, good tyres on the back. Come with centre caps but i prefer without personally.
  • 3 weeks later...
