Hello people just some stuff to get ride of
1.R32 GTR bridgestone shocks+springs
lower than standard great stiffness
350 ono for it
*fits R32 GTS4 and GTR*
2.RB26DETT oil pump off R33 GTR Vspec
120 for the pump
3.RB26DETT pistons
off a R33 GTR Vspec
150 for the whole set
4.Stock Front pipes RB26
*100*
5.Rb26 Airflow meters
300 for the pair
6.Stock RB26 injectors cleaned and flowed
300 for the set
ALL ITEM LOCATED IN SYDNEY
WILL SHIP TO INTERSTATE LOCATIONS
PLZ CALL ME ON 0410414307 IF U HAVE ANY QUESTIONS OR IF INTRESTED
All resonable Offers wont be refused
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
