Once again, why are you selling them? CAPA can be over-priced for items like that. I have been quoted $1400 for the same set new.
He won them in a Drift comp, and he drives a AE86, and a set of 18's 5stud aint really a match for the car
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
