I have found a link but not sure whether it answers my question still:
http://www.skylinesaustralia.com/forums/sh...ght=nismo+blank
It seems like R34's don't have a chip inside, but towards the end of the post there are people who are talking about electronic key blanks?
Now i am confused, any R34 owners out there who can confirm this for me?
Thanks
I don't think the gtt's have a chip in the key , i can tell you if i see the key .
The 34 gtrs have a chip in the key so if you want another key you have to get one from Nissan , have it cut then take it to them to program it .
the r34s don't have an electronic security feature like that found in the commodre or ford, so a plain key will still open and close doors and allow you to drive. Unlocking the doors either by key or remote will still turn off the factory security features.
