Was boosting last night and something was suss...
Was spiking up 3psi!!!
Runs 15psi but was spiking up to 18psi when boosting hard in third.
Going to test again tonight to sus this out before making a final judgement on whether or not to put my GFB Bleeder back on which spikes 1psi.
Hmmm... seemed to work fine when I first installed it...
just a question are you still running it with the stock solenoid???
if your boost is spiking at higher revs in 3rd this could be attributed to the duel stage nature of the factory solenoid.
how do you bypass the factory solenoid ???
does ne1 have any instructions for this???
and does ne1 think that doing said modifications will break my baby???
  • Replies 1.8k
Posted Images
Quote:
Originally Posted by simark87
Hi Guys, I will be offline until tuesday night in case anyone is chasing me..
Just a reminder to those who did not use a reference number when depositing for the boost controller. I still have 6 payments for which I don't know who they are from. To date, not one person has made contact about this
Cheers all
Mark
One of them is me! What do i do?
Just a note to people. Remember the number Mark gives you! I bought a controller off him and it arrived no problems.
He's doing the right thing by you so help him out a bit huh?
anyone got any installation pics on an R32 GTSt? I think I'm right but would like to see someone elses to be sure.....
installed mine today! Its running ~12PSI. Drops to 11PSI near redline though no fault of the boost controller more a turbo thing... Pulls very well, boost comes on no earlier but it does come on stronger. However I did give myself a 3rd degree burn on the dump after the runs trying to tighten the lock nut. :D
oh well, you live and learn.
cheers
simark .. i made my deposit on thursday morning june 9 i put my reference number in the netbank form ....but since it was a public holiday yesterday ..perhaps it'll be here this arvo or tommorrow.. if not i'll email you directly.
Matt
I do have one problem with the controller Mark, its upped the power and had caused my clutch to slip hardcore in 4th, might have to fix that :) he he.
Still not over it, took it to work today, what a difference to before. (when the clutch grips)
is anyone else experiencing the problem dee33 is having with boost spiking from 15psi to 18 psi? cause i bought mine already and cant wait to put it in but just worried of this happening to me cause im already on 13.5psi with stock turbo and dont want any spiking.
Nah I can get some on the weekend though...
I can explain it for now.
You'll have to remove the two intercooler pipes between the turbo and the carbon canister to be able to get access to the wastegate actuator. I unhooked the hose from the wastegate actuator and then plugged this into the bottom of the boost controller. I then ran a length of fuel hose (what I had) from the side nipple on the boost controller to the wastegate actuator.
The controller sits up right next to the passenger side strut tower. Took me a little while cause there is zero room to move near the turbo.
Just took it out after that and it was just a matter of fine tuning. Be warned it does locate the boost controller within 8 inches of the exhaust housing and that gets hot after a couple of runs. :D
A better idea might be to get a joiner thing that you can join two hoses together to bring the controller further away, might help in the fine tuning stages. Either way, it works fine and is well hidden out of prying eyes. If the boys wanna get down there to have a look they can be my guest :D he he
EDIT: tried to get pics but you can't see anything, there's too much crap around it. Follow the instructions and you should be fine, its pretty straightforward.
Run lower base boost then even if you get a spike you will save ur turbo exhaust wheel from ending up in your cat.
Got mine yesterday will install it in the turbo diesel and see how it goes.
i'm getting mine soon.. I cant wait. However, I got a question for you guys.. I have a R32 GTS-T, and I've done no mods to it except a pod filter and a boost gauge. Its running 11psi at the moment(I have never boosted it).. What do you think i should boost it up to, keepinging in mind i got the stock intercooler. I dont want to blow the engine or the turbo so any help would be much appreciated.
Thankyou guys.
Thankyou guys.
personlly, with 11psi and the stock intercooler i wouldn't increase it at all just yet. on an rb20 i think 12-14psi is safe if you have a FMIC but you don't
really, its up to you - its your car
14psi is great........ fitted mine today.. didnt expect it to run 14psi ... but gave my a surprise when the boost came in.. and fuel cut got me in 2nd :D
its still dropping psi off at top end like b4 ..bout 2-3psi after it makes full boost..not too fussed.. only stock turbo ....got it back to 12 ..goes nicely. no fuel cut yet ..
Matt
Angry...
What turbo are you running?
I've found the stock RB20DET turbo has issues holding more than 12.5-13psi.
A nice free flowing 3.5" does help quite a bit.
The Rb20DET turbo on the rb30det has issues holding more than 9psi.
So its definitely a turbo issue.
    • haha don't worry I'm sue you've got more fun ahead buying a 30 year old turbo car....but at least you are in the right place to ask
    • some days eh? The keyless entry and interior light on/off with the key will be controlled by the Body Control Module, but I'm not certain where that is or what it looks like (you might get lucky with a search to get a part#, which could be printed on it). I'd start at the A pillar/ Under dash/kick panel on the driver's side
    • It might be hit and miss, but Nissan Genuine Parts and Pitworks are not the same thing, although both are available from Nissan Dealers with Nissan Part Numbers. Nissan Genuine Parts are the OEM stuff, Pitworks are their attempt to get people back from generic parts makers
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
