  • Replies 1.8k
Posted Images
VAPE you are a legend man!
finally someone put up a detailled view of it :ermm: ...
so it works fine and holds boost constant?
Cheers mate,
-JD
PS:
Your hose looks like its not fully secure.. actually it looks like its not even under the metal tie...
Edited by JD-33
finally someone put up a detailled view of it :yes: ...
Cheers mate,
-JD
PS:
Thanks JD.
Holy crap, i didnt realise that hose was not secured haha. maybe that is why my hicas light is on lol.
I got so confused about eveyone's directions on that controller, even the picture that was sent with the unit in the mail didnt make sense to me. People seems to put it in different ways. So I tried the manual version, and nothing happened, less boost and nothing when i turned the screw. then did it another way and it was overboosting like mad, so i had to unscrew coz i crapped myself thinking it would break somehting lol.
Anyway, thanks for pointing that out!
Vape
Thanks JD.
Vape
That "unsecured hose" is just a protective sleeve for your power steering line. What you have is normal and is nothing to worry about.
if any one can help my freind want's to know if you need two of these to run a 300zxtt.
If so how will it be needed to be tee'd.
the reason i ask is because he is so impressed with my jrdsports mbc they have a special of bulk buy and he want's to get some boost running through his mildly worked 300
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...AMESE%3AIT&rd=1
hey guys can anyone help me out? bought one of these, installed it on my 33, if i run anymore than 8psi boost it splutter, misses and carrys on between 4000rmp n 6000 rpm. i got some free dyno time (only kw reading, couldnt ajust ecu) the other day and had a play n the best rwkw figure i could get was only running 7.8psi boost! do i need to get on a dyno that can adjust my computer (timing, air fuel? also why do u thionk my car can only run low boost wen i hear of other people on here being able to run 10-11-12psi on the same car and not have any worries!
thanks 4 the help!
cheers
brett
Mark,
Transaction made via internet banking. Reference number quoted...
Cheers....
Did he reply back to you, i have been trying to get a response from him since last week, through here and through eBay. I would like to purchase it through here but i do need one soon.
I dont care i would order one through ebay if i really had to but if he cant reply to my messages, how is he gonna send the item if i hit "Buy It Now".
I would like a reply just for acknowledgement at least.
thanks 4 the help!
cheers
brett
try gapping you plugs to .7 or .6 and see if the miss disappears.
I suspect the miss is coil pack related from the symptoms you have described.
Hey guys just put this on my wrx with 181@ wheels on 16 psi, my old controller shit itself couldnt create no more boost. put this on and it totaly kicked its ass, hits 17psi by 3200 in 4th gear and holds it perfect there. im so glad i got this instead of something else... Took me about 1 minute to put it on and about 30 secs to adjust and i was soo happy with this product best 42 dollars i ever spent.
just got mine ine the mail! cheers buddy ill shove it in the weekend and see how it goes. took aa bit over a week to arrive but it says next day delivery lol. Dont really care as long as it gets here looks pretty good. thanks a lot to vape looks easier now
man just installed it, couldnt wait :) warmed up the car then stopped shoved it in on the side of a 70 road then checked what boost...it was a little bit "infinite" for my liking i had wound it out as far as possible and was expecting less than stock. turns out i used the wrong hose and after i figured it out (no net on the roads edge) it pulled to the mark between +7 and 0 on my stock r33 boost gauge.. in 2nd at like 2000rpm! kicks in hard used to sorta build over a second now its just bang. im not one to go over 3-4k rpm so im very happy with the result.
on r33 gtst, it is the two LARGEST DIAMETER hoses that are connected to the controller, everything else you can block or remove. Stock solenoid is taken out of the loop by removing the t piece and its small hose and plugging the other hose with a screw or similar. use the existing clips to hold the hoses to the controller and shazam u pull like a v8. a big v8.
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
