fugi: find where your wastegate line is, and just put the controller in that line. don't go running it from different locations than the stock setup.
sorry to be a noob, but i cant find it..
so you saying those lines that i took a picture of arnt used in puttin the BC on??
Is that even my bleed valve??
Plz help..
  • Replies 1.8k
Posted Images
yea i saw that post and i posted a pic of what i thought was the r32 version of it. but i was told that i had to find somethin else. Is the pic i posted not the same thing but in in a 32???
But thanks Munkyb0y.. try to take a look at the pic i posted maby u can explain what it is.
Edited by Fugi
fugi, i am not familiar with the r32 at all, and i dont wanna start guessing.
CALLING R32 OWNERS !!!!
lol
R32 is as simple as it can get.
There's a nipple on the turbo's compressor cover, a hose runs from that to the actuator. Simply shove the bleeder int he middle of that hose.. You can't cut it as its too short; head down and buy a length of hose.
Thanks monkeyboy but ur guessing is probly better than my guessin.
Ohh cubes i didnt want to install a bleed valve i already have one of them. i want to install the turbotech BC.
Dose you instruction still apply??
cauz if it dose that means i will have to take off the heat sheild. The screws on it are stuffed..
and also what do i have to do to my bleed valve?? remove it??
Edited by Fugi
Do you guys tend to leave the stock restrictor in place. I Had mine out and the boost sucked, i could not turn the controller in much to get 10 psi, so teh spring hardly did any work. I migth try it with the restrictor in place.
your talking about that little brass thing in the hose before the BC?
I left mine in, BC seems to work great with it in. I wondered myself if should take it out.
i don't have a restrictor in mine. i put a new bit of hose on there. didn't seem to affect it at all.
fugi- yes cubes instructions still apply. when he is talking about a bleed valve he is talking about a boost controller. doesn't matter what type.
i brought one of these of a member and it's rooted had it on 2 diffrent cars and the boost just shoots up to 15 pound adjusting the spring does bugga all . i think the previous owner put a differnt spring in it for some reason :-(
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
