its just Swedish Touring Cars II reskinned..
tisnt much fun, cant wait for Toca Race Driver: V8 Supercars.
ive played the demo with just the supra's in it.. and DAMN its good, excellent graphics, physics and car damage.. tyres rip off rims, hatch's/doors get sucked out from wind if theyve been dented etc. also seen a few videos of the game with the V8's in it and it looks absolutely awesome...
expected for release in september or so.
reskinned v8 to a r32 from V8 challenge, i quickly grew bored of the game and started searching through the directory's. very lame but funny :cheers:
Shaun
https://www.sau.com.au/forums/topic/734-v8-challenge/#findComment-16761
Yeah I play it all the time, its not the best car sim game out there, but I've been waiting for years to through a virtual car around Bathurst with this game and a broadband connection theres hours of fun to be had.
Bathurst PB 1:54:80 no shit!
My user name is GTS25t
My team name is SDU
I'll email you my setup if you like:p
https://www.sau.com.au/forums/topic/734-v8-challenge/#findComment-17137
    • Hard to say, just pop the rocker covers off and have a look if you think it's cammed. You probably need to replace the valve cover gasket/half moons anyways.
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 馃槩
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
