  • Replies 48
  • 3 weeks later...
Please report back on the pedal feel, bite and the dust factor between the two.
LUCAS alot of dust, 1 week after putting them on started making noise again
this is a nightmare!
I got a 2nd opinion, about lucas break have been advised they are really bad for the discs mechanic told me that i would go through 2 sets of discs for ever lucas pad.
he recommended me another brand which is a subsidiary of bendix i forget what they are called, he said where bendxi use the medal compound this brand uses another compound - very reliable breaks, no dust and no noises
Sorry for the breif information i will provide more on this when i speak to him next
A few standard procedures for pad replacement, I always;
1. clean the pistons of the old pad dust, dirt and grit that accumulates there
2. clean and refit the stainless steel backing plates
3. clean and re-lube the sliding shafts and ramps (if they are single spot callipers)
4. clean and smooth the pad retaining shafts (if they are 4/2 spot callipers)
5. retension all the calliper retaining bolts with a tension wrench
6. remove and clean the rotors, not just the braking surface, but behind the hat where it seats on the hub.  I also give them a light hit with some course emmery.
The concept is to remove any particles from the contact areas that can cause rocking or vibration.  That's what most often makes brakes noisy, high frequency vibration.  It is most unusual for pads to cause noise from their friction action on the rotor surface.
I hear ya, i never knew there was so much too it i thought any mechanic can put on brake pads but obviously not
Thanks again :P
Whats the tension for R33 GTS-t caliper retaining bolts?
I used lucas pads on my 180sx and found that they created way too much dust and i'd never run them again...
  • 3 weeks later...
Does anyone know Winmax sports brake pads?it doesn't make much noise and it rated 0-500 degrees celcius.it definitely better than Bendix and does comparable job as those big brand such as project mu. i've got few sets of Winmax pads on hand for both R33gtst and 34 Gtt.
$170 for front and $160 for rear. $320 whole set! pm me if interest~
im over it , they are still making noise i just dont give a 5hit now
every1 has there own opinion on this matter each mechanic i went to says something different, my uncle the mechanic looked at my discs and thinks that the mechanic i went to didn’t shave my dics
who nos
mate
i had the exact same problem with my 33. i tried everything and i do mean everything, machined the discs several times and tried about 4 different types of pads. in the end i went to Race Brakes at Wetherill Park and changed my discs to slotted and it stopped! ! ! Brett at Race Brakes told me that my discs had a very slight lip in them and this was what was possibly causing the noise. He also explained that sometimes in machining a discs the outer rim on the disc in not machined causing a lip and noise! something u may want to look into
mate
how much did that cost you?
  • 4 months later...
Sorry to bring this up again
ok this is what happen, and im still having the same issue
what i have done
machined the dics again - same issue
now my uncle and i cleaned my callipers, cleaned the pistons basically done what SydneyKid suggested. and for a Week it was bloody great not one noise and i was so happy, then i drove towards Katoomba and on the way back it came back and its as worse as before. Hence why my uncle and i came to think the callipers including pistons etc are causing this noise. My uncle advised to get a new caliper set the one where they have only 2 pistons rather then 4hour at the front and a 2 piece set rahter then the standard one piece caliper, Peter from Advan recons thats crazy because im down grading my brakes. I took it took a "brake specialist place" and they looked at it for 10 mins and said i need to replace my front discs because they are too thin and need new pads all up $800 now in my point of view thats $800 bucks spent and problem will still be there because i know for a fact my back discs are also making that noise!
Please help
maybe i should just get for new discs like the brake man said but im worried if i sent $1500 bucks and the issue doesnt get fixed!
It would seem that you have a problem that is causing the brake squeel but it isn't the brakes themselves. Since you have changed pads and rotors, had the rotors machined etc. Several times by the sound of it.
Plus you are unique, I have not had a Skyline that I can't fix the brakes with the usualy service list (as previously posted). Whatever the problem is, changing the callipers won't fix it, they are not the cause. You must be doing something unusual, or live somewhere that the local conditions are causing it or maybe your car has some parts that are actually the reason (not the brakes themselves).
From what I have read, you do some work and the squeel is not there for some days. Then it comes back, this is not normal and it is going to take some extra effort to find.
Let me try some left field things;
1. What you you wash your wheels with? Don't laugh, I had a neighbour that washed his wheels with dishwashing liquid and his brakes would scream for days after it.
2. Do you live near the ocean? Or some large body of water?
3. Do you drive on dirt roads? Whereabouts are you actually located?
4. Have you checked the wheel bearings? If they are loose or dry (no grease) they will cause the disc to vibrate (at high frequency).
5. My uncle's brakes used to always squeel, because he was a whimpy braker, they never had any heat into them. So they accumulated gases that didn't get burnt off. I would take it for a drive for half an hour for him once every few months and the scream would be gone. (He reckoned I was a genius brake mechanic). Have you tried hammering the crap out them. Drive around with your left foot on the brake pedal for a few k's. Get them so hot you can smell them. Smoke is good.
6. Wheel nut torque, I hope you are not overtightening the wheel nuts. That can cause the rotors to warp eventually.
7. Have you tried borrowing some wheels? When the brakes are squeeling consistently, swap the wheels over and see if it stops.
8. When the brakes have been squeeling consistently for a couple of days, try hosing out one of the front wheels, in the morning before you go anywhere. Give it a good flush around, splash out any loose dust etc.
9. Do the pads wear flat? If the calliper has a sticky piston it will wear the pads unevenly, they will be tapered away from the that piston. A frozen piston makes the pad chatter, but a lazy one can make it squeel.
Let me know the progress
:) cheers :O
Edited by Sydneykid
Sorry you must have mis understood me i haven’t changed my discs yet just needed to know if that is whats causing the problem since i didn’t have this issue until i changed my pads and got discs machined.....
1. wash my wheels with the same stuff i was my car with NXT Generation Car Wash
2.3 I live in western subs in syd (Blacktown area) no dirt roads and no ocean
4. i have checked the pistons pretty oily, and not dry.
5. tried hammering the brakes a few times, even tried braking with my left foot, this issue happens after 10 mins of driving when they start heating up. and only on light braking.
6. tightening the nuts as normal not over doing it, noise comes from all 4 wheels
7. have got my stock wheels might put them on and see if that’s the issue i hope so
id rather spend my money on new wheels :)
8. done that alot of dust comes out bloody Lucas
9. haven’t check this one but will do
just for further info, this problem was fixed after cleaning the callipers for a week then issue came up again so thats what led me to believe it was the callipers
but looks like i might have to buy new discs and pads after trying the things you suggested
You know any places I can take the car too?
Thanks again Sydney Kid
Edited by Babylon
  • 6 months later...
Hey boys i took the car to bel's the other day regarding this on and off issue.
So weird the guys at bel took my pads out and straight away the guy said what’s causing the noise is the fact that i don’t have "shin pads" never seen it before in my life he said he cant understand why they are not there. It would explain why the noise is coming from all wheels because none of the wheels have this.
Just a quick question if anyone knows how much they cost?
  • 3 weeks later...
My brakes make a squeaking noise like there is a high spot on the discs themselves as it happens slowly when im driving slowly and fast when im going fast.
i took all my wheels off and spun the disc and its where the noise is coming from.
i agree it makes you feel like your car is a pos but bleh who cares in the end.
i think my discs have been machined as there is a lip on the outer edge.
when i can afford it im going to get a set of DBA slotted rotors and better pads and hopefully they will sound abit better.
cheers
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
