Does anyone know if the bearings assemblies are the same for the RB26? The RB25 ones? Bearing Industries thought they might be, but were not sure. Just want to confirm before I purchase.
Cheers,
Dan :)
When I inquired at Bearing Industries, they did say that if you bring down your old bearing/s, they will match it/them up with new ones.
So you can give them the part numbers to see if they have stock, then take your's down and compare before you buy!
But, from the above post, it looks like you don't have to worry...
  • 2 months later...
Idler: NSK 56TB 2801 B01
Tensioner: NSK 60TB 0683 EA7L 806
I think the idler was the more expensive one (about $48). The tensioner about $28
These were for an R33!!
Not sure if R32 is the same. The tensioner is the same as for VL commo hence its cheapness.
Sorry for bringing this thread back..
Can someone else please confirm these part numbers for the ECR33 tensioner and Idler pulleys/bearings.
I have seen a few different numbers. I know CBC has apparently got a different number, it would be good to have the genuine NSK product numbers and possibly even the CBC ones so there's no confusion.
Thanks
i got mine from bearing industries in yennora yesterday
$82.50 for the pair
no idea on the part numbers tho, the guy at the shop knew what i was looking for straight away
edit: for an RB20 by the way
Edited by r32woohoo
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
