Was thinking of selling my TEIN HA's and getting a new set of these....
Does anyone on here have a set, or has been in a 32 with some?
Just a friend put some in his 4 door 32 and JESUS these things were HARD!
And plus for the price they are a real bargain, plus they are 10way damper adjust. too....
If you can read japanese check it out at.....
Silk Road RM/A8
https://www.sau.com.au/forums/topic/73635-section-rma8s/
i am that friend... they were meant for my r32 4 door but due to financial restraints i had to sell them to another friend with a 4 door 32...
i did alot of research into coilovers for my car as it is a purpose built dedicated track only drift car...
everyone goes hks, tein, cusco, kei office etc etc... i thought id be different... went searching and found awsome reviews on the SilkRoad Section RM-A8 coilovers... theyre very popular in the USA driftscene with praise coming from all angles... and also in japan and hawaii
heres the USA link http://www.silkroad-usa.com/
get them sam! i can order them whenever youre ready :P
- adz
https://www.sau.com.au/forums/topic/73635-section-rma8s/#findComment-1352371
Silk Road RM/A8
Front spring rate is 560 lbs per inch (standard R32GTST is 125 lbs per inch) and the rear spring rate is 450 lbs per inch. Hope you never have to drive it on the road. :D
https://www.sau.com.au/forums/topic/73635-section-rma8s/#findComment-1353922
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
