I have just had a Power FC fitted and tuned in my R33 GTR, and even though the tuner said he would keep it "lean" at cruising revs, it now uses more fuel than on its original computer. Flicking through the menus on the Power FC hand controller, its shows readings for the two O2 sensors. Deeper in the menu there appears to be a setting for O2 and a Japanese character. My questions that someone may be able to answer for me are
1) should both the O2 sensor reading be active with the motor running as only one of mine seems to register ?( a stuffed O2 sensor?)
2) can you set a Power FC to run closed loop and help low throttle cruise consumption?
Any help greatly accepted.
https://www.sau.com.au/forums/topic/73700-power-fc-closed-loop/
yep, power FC can run in closed loop. there is an option to turn closed loop operation either on or off. both sensor should be reading whenever the engine is running (assuming we are talking about a gtr here) is only one is registering then the other one is stuffed and replacing it should help fuel ecconomy.
you need to go into etc menu and choose 02 feedback control. the symbols are like this:
well running with one stuffed sensor will certainly effect fuel consumption as closed loop cruise wouldn't (or shouldn't) be operating properly. you can disable closed loop operation and have your tuner spend some time on the cruise areas of your fuel maps to give a pretty economical result. or just buy a new sensor.
  • 3 months later...
hmm im just trying to understand it all.. been searching.. :huh:
but anyways is closed loop when its not using the load points/values on the ecu ?
like if i had no o2 sensor and my pfc was tuned at all the low points it would be fine ya ?
Yeah closed loop only uses the low load 'cells' of the map but I am not sure of the exact specifics.
But yeah the engine will run fine without closed loop. But if its constantly running rich, that means you'll have more carbon deposits in your combustion chamber and anything coming out from it.
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW )
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
