OK so we have had the nasho and we have had the road on the way to new port, the next logical step is the old pac. AKA The old Pacific Highway. Thoses of you who havnt done this road before it is less bumpy than the nasho and has all types of corners, tight hairpins, long sweeping lefts and rights and fast chicains *spelling*
So whos up for it?
Date: Friday 10th June
Meeting place: Thornleigh Maccas 9:30
Departure time: 10-10:30 depending on how many people turn out.
Depening on how many people turn out old pac can be run in 3 stages.
Berowa to moony moony, stop at the servo there.
Moony moony to Petes ridge. If there are too many people we will have to miss this stop
And Petes Ridge to Wisemans ferry road industrial area.
Confirmed:
Aplex
gts4
Moanie
Liz
Minite
Rukus
Shonen
Wilch
BLK R33 GTST +1
Silver
HCR32
Henzie
Sl!m
T04GTR
R33deviat (reprezent da cefiro cr3w yall, 3ast sid3)
76
Giffo
ecl
Bizzrevhead
GT33
MAR55S
Hanyou
E_Lu-Shun
Mr 350z
Ed R34
LANHOF
Maybes:
Mik78e
Shonen
KNG-32R
WilliamsF1
Sawakita
KILL HSV
https://www.sau.com.au/forums/topic/73720-old-pac-june-10th/
  • Replies 330
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
