mmm does anyone know how to use one of these?
It is pretty simple............
There are 2 settings, Boost (that controls the amount of boost) and Duty (that sets the solenoid duty, controls the boost climb rate). There are 4 options for boost level, I have mine set as follows;
0.70/48
0.80/54
0.90/60
1.00/66
So 0.7 bar has a fast climb rate and 1 bar has a slower climb rate.
Hope that is of some help:cheers:
PS, there are instructions in the Commander manual.
  • 2 months later...
Hi guys,
I now have my PFC boost control kit hooked up, and it doesn't seem to follow the logic above....
1 0.70 kg/cm2 48255
2 0.75 kg/cm2 50 255
3 0.80 kg/cm2 54 255
4 0.85 kg/cm2 56 255
When I set the max boost for 0.85 kg/cm2, the duty cycle seemed to affect actual boost more than the boost setting.
ie: 0.85 48 gave 0.7 kg/cm2
0.85 70 gave 0.9 kg/cm2
I mucked around and found that 0.85 66 gave the correct 0.85 kg/cm2 max boost level. This seems to match the Apexi AVC-R instructions
which say:
"When max boost of ACTUAL driving is HIGHER than target boost, adjust the duty LOWER. If the max boost of ACTUAL driving is LOWER than target boost, set the duty HIGHER"
This doesn't make sense to me, as the whole point of closed-loop boost control is that the ECU should work out the correct solenoid duty cycle from the pressure sensor, not need to have it keyed in!
Also, if the boost is really controlled by the input duty cycle, this makes a lie out of altering boost climb rate by changing this variable...
Two other things have me wondering:
1) Why are their four lines for different boost levels?
2) There is a third column, which is set at 255 for all rows and can't be changed via the hand controller - what is this number?
Any help welcomed (especially from Sydneykid!)
Cheers, Peter.
Hey There.
I also have the PFC boost control.
The way it works is that the 0.8,8,9,1.0 Bar settings sets the max HELD boost. You will find that no matter what the other setting is, on sustained full throttle, the boost kit will hold at that boost.
It may spike however if the duty cycle is too high a number, which will bring boost on really fast, it will spike and then settle down to the max boost number.
The 255 bit, is a non user adjustable display. When you change the max boost number, this goes back to 255. Once the PFC has learnt how to control the set amount of boost, this number will change to a different number, which is simply a display number. You cannot adjust this.
You should asjust the gain so that you don't spike the boost. You can check this by watching the line graph whilst ramping through the boost.
BASS OUT
Thanks Bass,
That makes sense - the peak reading I was getting was from the peak-hold function, and the actual boost may well have settled back down to a steady 0.85 after the spike. I will look at the trace line more closely.
Sounds like the duty setting I have now is as aggressive I can get in boost climb rate without overshooting.
Nobody has an answer on why there are 4 lines tho' - if you can control steady peak boost with the first number and climb rate with % duty cycle, why do we need any more than one line of code?
I will keep my eye on the 255 number, but it has not changed so far...
Cheers, Peter.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
