  • Replies 62
Stich9 - I LOVE them in Yellow to.... I was only going to get a rex if I could get the EVO 4..... found one thats been garaged for a year.... mate it AWESOME.... you should hear how loud it is... beautiful note...
Dan - yes definately be running it ... am sourcing a ECU tomorrow...
Hopefully have it before the weekend... so ill show you...
Anyone want to cruz on Sunday.....:)
Dan
Originally posted by IMACUL8
As of 15 minutes ago Im now the proud owner of a
2000 WRX CLUB SPEC EVO 4 Limited Emidition
:D :D ;):)
I have crossed over.... hope you boys still let me cruise....
Dan
Welcome:D
I looked at a couple of EVO 4's too there is one at Joe Crifarios that they fitted silver wheels to.
It looked better but ruined the originality.
Decided to go new as all the EVO 5's were sold and couldn't find a demo.
Let me know what mods work. I've fitted a full 3" stainless system and it's barely run in but they sound great.
Cheers
how quick are the STi's WRX, it was a current looking one, the new shape, im only askin cause one pulled up next to me the other day, and we had a bit of a play off of the lights, he got me at the start, but in a matter of seconds i was back with him and stayed with him, not sure of the mods it has, all i knew is it had an aftermarket exhaust, anyone know how quick these STi's are???
Chris
I looked at that one to at Joe Crisafios...it was a piece of sh*t. Those silver rims looked crap and it was completely stock except for cat back....and had 38000km, also had 2 pin dents and a big scratch on the boot....
Mine on the other hand has done 20000km, Full Norm Butler Stainless steal exhaust, and HPC coated dump pipe (farken load), 6 cd stacker, Lowered on its arse, and is COMPLETELY unmarked... even has new car warrenty remaining... oh and key pad security....
We'll have to stick together Chris now.... hahhhaha
Daniel
An STi will do a 13.3 stock..... thats pre MY02 (bug eyed rex).... they lost 15kw.....
Dan
well, haha what can i say, he mite not have been trying, or mite have just been a standard WRX with STi badging, but theres no way my car would do a 13.3 down the strip, thanks for clearing that up for me guys...
:D
P.S. this one was a "bug eyed" WRX
Cam.
Chris
Daniel
Yeah it was crap..they'd had it for over six months
My missus picked that the front left guard had been resprayed.
I allways take her along as she can pick colour changes.....a spray painters nightmare she is.
Was going to look at one someware in Vic Park (Autostrada???) but decided to go new for not much more money.
Yeah go the rexes but I still love Skylines
At least your nick is relevant:(
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
