yeh i sit on the hill and laugh at a few 'CERTAIN' ppl!!!
Thats enough laughing at me from a distance PHat MR30 :wassup:
If we get the car ready then i'll have a drive, if im not there to partake then i'll be there to party :P
I'll be having to get the camera out if your driving GMB.  Might even get yours and take some pics for ya.
I'll expect you to wave as you drift round the sweeper.  :headspin:
BWAHAHAHAHAHAH
Yeah no worries champ, i'll be waving as i drift around the sweep while eating a cheesburger and singing "Afternoon Delight" :wassup:
Trying to get the car ready but has to go on hold for a couple of days while i get the dental work done, and if im not there doing it you can bet good money that Steve aint going to be doing it :headspin:
If we get the car ready then i'll have a drive, if im not there to partake then i'll be there to party :rofl:
Lol NO not at you, Phat R33 will know who i am talking about tho!!!
LOL, its cool man im just messing around. Be good to catch up with all you boys at the comp. Have to organise a place to meet up and bag out each other's girly ricers :headspin:
damn it Matt you have seen through my evil plan now!!!!
lol! he told me his mum is sponsoring his car for it!!! can speedy tyres put more camber on it for him you think????
Sounds like you boys have a different motive to going than the rest of us :headspin:
lol dave is a good bloke BUT it will be funny watchin him have a go he hasnt had it long and it is auto and all. i rekon mandy may beat him.....lol that evil plan was as see thru as pauly's timing cover lol
lol a mate of mine had a sticker on his scorpo that said sponsered by ur mum hahahahaha. put more camber on lol is that a joke?? or did i read that wrong lol
yeh i am very transparent aren't I!!!!
The day my mum sponsors my car i will post picture for sure!!!!
seriously! dave went into speedy tyres asking for more camber on his car cos Thorpey says its fully sik!
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
