I know ive only had it for 3 months but im looking for an upgrade.
so im willing to trade plus cash adjustment.
I purchased the car of (Heathgtst) on these forums and i have to say i was more than happy with the way he looked after this car.
since i bought it i got the whole front resprayed due to alot of stone chips on the bonnet and a dint in the drivers side gaurd.
Exterior
- dark grey with purple pearl
- trial front bar
- trial side skirts
- nismo clear indicators
- 18x9 drift r wheels with dunlop sp9000 tyres
Intirior
- m's shift knob
- gtr floor mats
Brakes
- slotted dba rotors front/rear
- rb74 racebrakes pads front/rear
Suspension
- bilstien shock absorbers
- pedders lowerd springs (%100 street legal)
- whiteline adjustable swaybars
- whiteline camber kit front
- whiteline camber kit rear x2
- whiteline castor kit front
- whiteline subframe align/lock (pineapples)
Electronics
- Apexi power fc computer
- apexi hand controller
- warlock alarm and 2 point immobilizer
Transmission
- standard 5 speed (always serviced with fully synthetic oil)
- exeedy 5 puck button clutch
Engine
- hks air filter
- custom 3" cat back exhaust
- race pace 3" hi-flow cat
- just jap 3" front pipe
- hks gt2535 turbo
- hks front mount intercooler 600x300x75
- hks 14psi actuator
- gtr fuel pump
- 247 rwkw on racepace dyno
car has 75.000kms on it and the timing belt and water pump were changed at 45,000kms
i have been pulled over numerous times before and they have tried to canary me but have failed.
this car is in prestine condition and one of the best r33's i have seen. It is %100 p plate legal as the tare wheight on the rego has been bumped up to pass the power to weight ratio
i recently got an epa off with the turbo and computer still on the car(the only thing i did was put a small muffler and stock airbox on.
the intirior does not have a mark on it, and it handles and brakes like a dream.
when the car is purchased i will have it re dyno tuned at my own exspense as i want the new owner to get it running perfect.
Only reason im selling her is to upgrade to an r33 gtr
Price $24,000 firm
or trade r33 gtr + cash
https://www.sau.com.au/forums/topic/74166-fs-1996-r33-ser-2-250rwkwmspec2/
Make sure Ben from RacePace does the Retune mate.. pm me if u dont have his email, he has tuned it the whole way along the mod train and had to spent 2 hours fixing someone elses "tune" when it was taken somewhere else! Good luck with the sale.. id buy it if i wasnt in the same boat as u & wanted a GTR :P
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
