Hi Guys,
As I am having my new exhuast manifold built I am planning on getting it ceramic coated in preference of heat wrapping or shielding, with a number or articles pointing to it's benefit in removing heat from the engine bay etc.
I have found a place in Perth which looks like they do it, Competition Coatings, located near to the motoplex. Has anyone dealt with these guys, had experience with ceramic coating etc.
I will talk to them on Monday and see what the rates are, is anyone else interested in having anything done as I can find out prices at the same time. I think you can get the exhaust housing of turbo's done with this method, which would look pretty cool.
See'ya:burnout:
https://www.sau.com.au/forums/topic/7420-ceramic-coating-in-perth/
Originally posted by GTS-t VSPEC
Hi Guys,
See'ya:burnout:
I think they might have been B&B coatings in a previous life. If so they are very good. Coating the exhaust manifold is a good idea, and the ic pipes as well.
For those interested wrapping the aftermarket dump pipe is a great little mod for not much cash. Themotec make a blanket and tape package for turbos (blanket goes on the turbine). If you don't go the whole blanket thing then just the tape is good also (thats all I have).
rev210,
I like the cleaner look of the ceramic coating, although in the end the results are probably very similar. It should be worthwhile trying these guys, as the major expense use to be freighting the stuff over east.
Don't know how much it costs, I'm hoping its not too expensive. I wasn't going to bother with the intercooler pipes as they are polished stainless, I like the look. Hopefully if I get the exhaust manifold and turbo exhaust housing done then it will reduce under-bonnet temperatures. Have you noticed any difference with the wrapping/thermotec?
By the way, that is a very good 1/4mile time with the stock IC, well done.
See'ya:burnout:
Hicks,
Not yet mate. What we're trying to do is get another RB25DET, do all the work on that and then drop it in to my car. That way I won't be stuck walking and catching public transport, while my car is being done.
Hopefully, all going well, the stuff will be in during 1-2week of January.
See'ya:burnout:
rev210,
See'ya:burnout:
Mate. I know soon you will get over the under bonet vanity thing because you now own a real performance car.:) When that magic moment arrives you will have no hesitation in ceramic coating the ic pipes.
Under bonet temp wise the tape is very good indeed. You can put your hand on the dump pipe straight after a drag race, when you know underneath it is glowing red. If you ever pop the bonnet with the engine running after a belt, you will notice a great deal of heat comes from the turbo/dump area, this is all but gone on mine.
Under bonnet temp is the secondary benifit BTW. The main benifit comes with trapping the heat energy in the pipe and converting it to gas velocity (pressure along boyles law lines).
GTS-t VSPEC, I would be very interested in getting my dump and front pipe done. An idea of price would be good, and a big thanks for your help.
Cheers
Steve
rev210, If the ceramic coat thing doesnt pan out, I will be thermo wraping my dump/front pipe (maybe even both coat and wrap:D ). Where is Thermotec available through, who would you recommend to do the job and what sort of dollars are we talking(dump/front/turbo blanket)? Hope thats not too many questions, any help is very gratefully received.
Cheers
Steve
Cheers
Steve
Most performance shops can get the stuff (thermotec). I prefer DEI Engineering stuff myself as it has a nice marker running the length of the tape for even wrapping. Bout $120 for the 60ft roll of 2inch wide DEI from revolution race gear, which is a little more than the termotec but worth it. The turbo kit from thermotec is about $150 -$200 from memory.
Do the job yourself. Its not technical, just hard work that requires a little patience and a couple of hours.
Here's how I did mine.
Ingredients: 60ft roll of tape / stainless steel hose clamps / large plastic cable ties / High temperature (silicone based) paint of your favorite colour.
1) clean the pipe to be wrapped / sand lightly.
2) paint evenly with high temp paint.
3) cure the paint by driving the car around and cooling down as per can instructions.
4) wrap the pipe evenly all the way along. DO NOT over wrap or under wrap sections out of slackness. Use plastic cable ties along the way to keep wrap in place.
5) Spay the wrapped pipe again with high temp paint, to seal off any slight air gaps.
rev210,
How much length will the 60ft cover? I am trying to determine the cost difference between the ceramic coating and the thermowrapping. What was the total cost, excluding your time, of thermowrapping your dump-pipe?
See'ya :burnout:
rev210,
See'ya :burnout:
less than $20 for the odd bits
$120 for the tape. enough to do the back of turbo to cat and inlet pipe on the stock intercooler. Bits still left over somewhere.
I'd still use the ceramic coat for the manifold the same, it would be a right pain to wrap.
GTSt VSPEC
Would be very interested in the prices you got today for the ceramic coating. Looking at doing this at some point on exhaust and ic piping. May also look at redoing the rocker cover in a red crackle look (as per ferrari has). Not sure what colour the exhaust etc will be done yet, but was my understanding that you can keep the polished alloy look or choose as specific colour.
Cheers
Brendan
VSPEC2,
You may want to be sure that your talking about ceramic coating versus powder coating or HPC. Ceramic coating is primarily for very high temperature conditions, such as exhaust and is desgined to keep the temperature in the exhaust gases and not in the pipes. I belive that the ceramic coating only comes in a few colours, whereas powder coating and HPC are more varied but do not provide the same level of heat protection.
I will be going there in about 1 hour and will post any info tonight.
See'ya:burnout:
Thanks dude. Yeah, I know there's some differences in the coating and nomenclature used to describe them all - I think that HPC comes in a few of different varieties as well for different heat and 'high non-wettable oil shedding' coatings:
http://www.hpcoatings.com.au/pages/auto.htm
Let me us know how you go.
Cheers
Brendan
Well I did try and see the ceramic coater this afternoon. I finally found the right street, no f#cking street sign, found the right driveway, and it was a f#cking dirt track. Now I hope you can fully understand that there was no way in hell that my lowered and cleaned skyline was going to make it down that 4WD dirt track. I know it's the f#cking sticks, Wandi, but at least surface your driveway.
So to cut a long story short, I went and left without getting to the place. I'll call them tommorow and find out for sure that they will do this sort of stuff before I have to organise another car to travel down there driveway.
Sorry I didn't get the info yet, but the Skyline would never have forgiven me. So I'll get back to you all in the next couple of days with further details.
See'ya :burnout:
My car does the dukes of hazard duties, I found out a while back skylines love dirt tracks, must be the hicas.
I did 100+ km/h on a floodway/ wet/ pot holed gravel track down south, lots'o'fun:D
rev210, you are a sick bastard, we are going to have to take your skyline away for mistreating it. I've got the number of the guy (ceramic coaters) and will call him this afternoon, I'll try and get some pricing info off him.
See'ya:burnout:
Your not the first to suggest this.
It's true I am not one for respecting a cars appearance(inside or out)but, mechanically my car is treated better than most.
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
