Since I received my new GTR from Japan I have had a flat spot between 2,000 and 4,000. It seems to be mostly around 3,000 rpm.
The ECU has been modified by garage SAURUS. For some reason it will stay in closed loop until 4,000 rpm. I guess it is one of their tuning tricks - or maybe it's trying to keep the fuel economy reasonable.
The turbos have certainly been upgraded, but I do not know what was done to them.
I also get turbo surge at 3,200 rpm occasionally, but do not know if it is related to the flat spot issue.
I know one of the oxygen sensors is slow.
I hooked up a laptop and a PLMS adapter to the diagnostic port and noticed that one of the RB20 AFMs was at about 2 while the other was at 2.5 when it was going lean.
A competent mechanic has looked at it and cannot find any air leaks.
I strongly suspect that it is not just a badly set up car. Someone has spent a lot of money on good gear, and I do not believe he or she would have accepted changes that affected the drivability at road revs - especially if it was something as simple as the fuel map being modified by a company as prestigious as garage SAURUS. If I cannot find any other solution I will try getting the fuel map modified, but would really appreciate suggestions on what else might have gone wrong.
I've put up another posting about modifying the fuel map.
https://www.sau.com.au/forums/topic/74289-gtr-flat-spot-question/
Sounds like what mine does but only when its cold for the first minute or two of driving, then something changes (assuming ecu changes from closed to open loop mode?) and its smooth. I barely notice it since i'm hardly on the throttle until my oil temp starts warming up and by then its gone.
What I would do....
First job, clean the AFM's, I use brake cleaner as it leaves no residue. Then recheck the voltages. Once you have consistent readings stick it on the dyno, connect all the dyno sensors (inc knock) and do a power run. Then have a good look through the graphs, particularly boost, knock and A/F ratios.
Garage Saurus are known for agresssive tuning and they use 100 octane fuel. So it is important to make sure the tune will handle 98. Flat spots and compressor surge are all tuning signs. Don't fark about, if it is lean and advanced you will kill it very quickly.
:P
What I would do....
:D
AFMs were cleaned by the competent mechanic. Prior to that I did a dyno run which has a nice rich (and uneconomical) mix all the way through.
By the way, the dyno-dude said he couldn't adjust the tune because the ECU had been modified. If a dyno shop cannot adjust entries in the ECU, how can they adjust advance etc? That's probably a really dumb question, but I'm still learning.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
