Just Had A Turbo Back 3" Exhaust Fitted
With A Ces Dump Pipe And Mandrel 3" Full
System With A Cat And 1 Muffler At The Back
And When We Started It Up The Idle Was
Up Near 2000rpm Solid And Then
Started To Fluctuate Up And Down Between
900 And 2000rpm, Its Like An Idle Control
Problem But It Was Fine Before The Exhaust
Was Fitted,
Any Ideas???????
https://www.sau.com.au/forums/topic/74972-new-exhaustbad-idle-or-r32-gtst/
First bet would be to check AFM as this will produce symptoms like you described and is easy to get to. It's a hard one to diagnose without looking at it myself but next step after that you could try checking all connections on AFM, TPS, Ignition module, cam angle sensor. After that I would try pulling an error code if it logged one. Go back to the shop that did it and ask to see their electronics protection device that they use when welding. Remember not to ring them and ask as they are easy to buy or borrow from somewhere else. Just go in and surprise them.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
