Last night driving home i pretty much had no clutch... stopped and found no fluid.....
filled it up an pumped it for 10 mins and it came back.. thismorning looked in footwell and there is fluid leaking all the way down the pedal from the small black thing that surrounds the rod... if you get what i mean...
Now ive searched threads and stuff and couldnt find a clean answer...
what do i need to fix/replace regarding this leak... is it as simple as a couple of seals or do i need a whole new master cylinder?
New or reconditioned?
Brake and clutch specailist??
And finally how much is this going to set me back??
Thanks
Ed
https://www.sau.com.au/forums/topic/75077-clutch-leaking/
beautiful.... nice and simple.. i was getting confused if it was a seal or something or a whole new thing... i take it jap spares place is the best bet? as normal places wouldnt have a clue???
thanks for quick response
ed
https://www.sau.com.au/forums/topic/75077-clutch-leaking/#findComment-1377708
yeah hi i have that same problem with my r32 you can buy seal kits for them but if you dont really know what your doing your best off just buying second hand
As far as im aware, they put in a new oversize cylinder, along with new seals. This costs about $270 from memory, but you need to wait for it to be done, then have the master cylinder put back in.
Or, do as i said, go buy a $70 new one. Two bolts inside the engine bay on the cylinder, and one clip on top of the clutch pedal. Not a hard task at all.
Never replace something worn out with second hand sheit. Asking for more trouble later....
https://www.sau.com.au/forums/topic/75077-clutch-leaking/#findComment-1377833
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
