thanks guys, i'll get the hammers out tomorrow!
Please Picture Document this brake swap for us, I REALLY want to know how its done :(
i've only started on the drivers side so far so i'll take pics when i do the other side, they'll be from my phone so not the best pics
If you are using hammers on the tops of the joints, leave nuts on or you'll f*** the threads.
machg
what your saying is leave the bolts loose so the bit i'm trying to remove can move just enough to loosen but not dig into the threads...
Yeah the easiest way is to slug it with a hammer and loosen the tapered joint. As what's been said, put a nut on the thread to protect it so the hammer doesn't damage it. I always find it useful to also pull the arm down, usually comes out easier this way.
got it off thanks guys, might need to machine the s-13 hubs a hairs width to let them slide on a bit deeper just so i can tighten it enough to put the pin back in...
thanks guys..
Machine what to tighten up to what??? You've lost me :headspin:
the steering arm bolt and the hole on the s-13 hub dont match, the hole is just to small to let it slide down enough to put the pin in place, i've threaded the nut trying to tighten it so i'll get it rethreaded or a new steering rack (need power steering anyway).
I think you will find that the s13 runs a tapered tie rod where the r30 runs a straight one. So they will need to be drilled out, I reamed mine for a nice tight fit.
it might be the other way round as the arm on the hub has just stopped, leaving about 3mm of thread showing...i might just get a grinder drill bit and trial and error it till it fits. i'll need a tap and die set too to fix the thread ;)
the best way to release the tire rod end from the stearing arm is this:
grab 2 hammers and swing the both athe the same time either side of the steeering arm... leving the nut on but loosely. you need to hit it with both hammers simultanisly in order to shock the taper locking the tire rod to steering arm, releasing the taper. may need a couple of hits, but this should do the trick. by leaving the nut on, its stops the tire rod end hittinfg the ground then you can undo the nut and remove the arm
i have done many a joint before and its worked a treat.... ( shown to me by my motor mechanic)........
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
