As long as your still running a pull type clutch in your GTR it will fit straight in.
Where did you get your exedy clutch? I thought they were only around 2500lb of pressure on the exedys.... Regardless if DIRTgarage are running it on thier car (450rwkw+) then it should be fine in yours yeah?
I'm assuming your running a GTR?
All clutches aren't built the same(hence why Jim gets such a good rep around here) if you want a multi plate, go for it - but i think the proof is right there - DIRTgarage running the same clutch (as a drag car) with 450rwkw+
I think Paul and Stacey may be able to expand on this a little :) But they aren't selling this to make a profit, they just have it left over.
DIRTgarage is Paul&Stacey (who are selling this clutch) PM them, or wait till they reply to this thread. Sorry no number for them :D
Not sure about the oil pump - find the part number and get your local nissan dealer to order you one in?
Yes im running a R33 GTR. Do u have the number from DIRT- garage ?
One last question, would u know where i can get a n1 oil pump from and how much?
Thanx.
I put Paul and Stace from DIRTgarage aka two.06L on to Jim Berry Race Clutch to try one of his race clutches. They were looking at getting a twin or triple plate which cost big $$$ as you know. Quite simply its superb and the best value for money clutch you will ever buy anywhere. Beauty of this clutch is its a single plate, some might scoff and say a single plate can't handle high hp, well normally no but a Jim Berry single plate GTR race clutch can. Its very streetable, no rattle like multi-plate clutches and can handle high rev clutch dumps all day everyday. With two.o6L now making 411awkw and 467rwkw and now with the Mickey Thompson ET's it requires an 8000rpm+ clutch dump to get off the line without bogging down and if you've seen the 1.65 60 foot times there is not even a hint of slip and like Paul says, 2yrs of racing and its still superb.
Simply the best clutch out there as for max hp thats unknown at this stage but rest assured it can handle very high hp.
Either contact Paul/Stace or me from DIRTgarage via pm and leave your number one of us will call you.
Cheers
Thanx.
Nissan , about $500
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
