  • Replies 60
6pm is cool with me :)
we'll just go for a drive around civic and braddon and northbourne or something...maybe find somewhere to stop and check out all the cars too...
2rismo, shit u could have crashed at my place!!...but i just offered my spare room to a friend from sydney (he drives a rotor :chairshot ) Actually he saw my pics from the Gong and he said he has met u before (his name is Rob...number plate QIK78U)
anyway, 6pm sounds good, I will see u luvly ppl there...and mark can make it after all yayyyyyyy!!!!! :)
mark, coming from civic, drive over Commonwealth Ave bridge and take the first left. Go straight ahead thru the traffic lights and keep going along that road...it'll take you past the Nat Library and the Nat Gallery is just past that.
i'll now be driving down 1st thing saturday morning and staying all day then driving home again...
my mates lj is on the dyno @ 10am saturday morning and i'm not gonna miss that for anything!!!
So i'll be in the dyno cell from about 9:30.
Hope to catch up with some of you down there. Might even stay longer as my 2 day passes turned into 2 season passes. Assuming I don't use them, does anyone want them to use on the next 2 days? I'll be back in the gong...
Adrian
I have to wait till 9am to leave otherwise. My mate that i'm going to cantberra with is a copper and his train gets in at 9am. fark that...miss half the day... so i'm cruising down on saturday morning...leaving wollongong about 5:30am
:D
Shell,
I'm in for a meet up again this year but so far I'm going on three different cruises on Friday night so I might bolt off early.:burnout: I've changed cars since last year but I promise to park in the corner if no-one laughs. OK:p
shell, as you probably gathered i didn't turn up yesterday, i finish work at 4:30, so i didn't get a chance to get your mobile number off the site.(i dont have a computer at home yet).
i endend up leaving at 2pm on friday, we were so bored.
sorry to stuff you around.
mark
ps. the nats blows big time
I went out to the Nats today. I thought it was ok, but Autosalon is way better! It's just way too damn hot at the moment to be walking around outside! Last nights cruise was a bit of a fizer! Eccept for that awesome R33 with Nos. That was nice :uh-huh:
Elite Motorsport's cruise went off though!
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
    • Did you even watch the video? Its not a steering wheel.
