Hi there fellows, I,m having problems with me car at the moment, every time i change gears it coughs, I dont know if it's running to rich or to lean but it is very annoying to hear this! this started after the car came off the dyno 3 weeks ago .can anyone help me please? or heard of this happening before?
Prior to that , the car was running perfect, regards.
Ps: my ride is a R 34GT t. :confused:
https://www.sau.com.au/forums/topic/75620-does-anyone-knows-why/
Hi El Bee, it was just to find out what Kw it reached (power only).
I've never noticed the excess fuel pop before and I guess was worried after the dyno run.
Thanx for the reply, I feel alot better now!
The car clicked 234Kw... stock with factory ecu (impul) .
234kw at the rear wheels? Thats a very very high figure for a near stock GT-T. Where was the dyno run at? Sure you haven't got a GTR in disguise? :P
What colour is your GT-T? Keep seeing a few more around the place.
I've got all the basic mods and can't decide whether I can start the more expensive side with diminishing returns.
Blitz front mount
Profec B EBC
3.5" turbo back exhaust
Dump pipe
Unichip and unichip boost module
Oil cooler
Apexi super intake
Currently making 197rwkw at 12psi.
A stock GT-T will pull about 160-170rwkw. Stock turbo and bolt on mods good for ~200rwkw. Anything above this will require upgraded turbo or high flow. No chance in hell that a stocker will ever reach 234kw. Either there are some serious goodies in that engine bay or your dyno figure is very optimistic.
Please don't think I'm trying to have a go at you, I'm just very curious as to how you got such a very high figure.
yeah well some how i got 216rwkw out of my "stockish" 33 at the auto tech dyno, dyno's are not a real way of telling power they are made for tunning cars thats it!!!!!!!!
Sorry as for the poping mine pops like all crap and once and while it will shoot a flame
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
