Hi guys/girls
I have a brand new genuine Garrett dual ball bearing T04Z turbo for sale.It's one size bigger than a GT35/40 and uses a 67mm compressor wheel (0.7a/r) and you have a choice of a single entry (0.96) turbine housing or the twin entry (1.00)
both housings have a v band.
This turbo is rated between 750-800hp and would be best suited to 2.5 litre or larger engine.Im asking $2000.
cheers
https://www.sau.com.au/forums/topic/75692-fs-brand-new-garrett-t04z/
Did you have the comp cover polished? Cause they don't normally come like that.
I'd prefer a T3 flange, to suit my existing manifold, but if your willing to drop the price then I'll consider.
Yeah I had the comp cover polished.As for the price make an offer just remember this turbo retails for $2400 so dont try to rape me :)
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
