Hey... I've got a stupid question..
I need to replace my battery.. it's constantly losing charge after a week of not being used... only problem is that on the GTR the rear strut brace is in the way and you can't get the battery out.
So my question is.. can I remove it and replace it myself?
Is it hard to do?
My only concern is that its a structural support and by my thinking may cause the strut towers to shift a little if removed and make it impossible to put back on.
https://www.sau.com.au/forums/topic/75742-r33-gtr-battery-changestrut-brace/
Depending on the size of your battery you could slip it out above the strut brace.. i can get mine out/in like that (gotta tip it sideways)... if you have a bigger battery you'll have to take the strut brace off. Did it once, can't remembe rit being to hard - you'll be fine. Its to help stop the body flexing not to hold it in place. :(
Is it hard to do?
I did mine mate and didnt have a problem.
Clarkey
Jesus Al, you been hiding? Best you be at the Sandown track day or the next club meeting for a catch up before I pi55 of to Qld. Probably leaving late July this stage.
I had a look today and the brace will come off easy as. Gotta be easier than trying to work around it. Even the GTSt is a biatch to work on back there.
Is it hard to do?
Just undo the passengers side and loosen the drivers side mate .
When you change the battery just do it up again dont adjust the centre nut at all and it will be the same as before .
Stolly,
I fitted a heavy duty battery to my R33 GTR a month or so ago, and despite looking a little tricky its an easy job.
Simply remove the single bolt on each side holding the rear brace in, then remove the battery clamp and prepare for a good half hour of leaning over and loosening off the battery terminals, as the others have said you need to use some care here, but essentially its a simply swap - out with the old, in with the new.
:rofl:
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
