im no longer doing the original style lid... as its too time consuming and tricky to fold. can be done, but the time it takes is way too long compared to the new design...
for that reason ive increased the price, i have to buy more bits and pieces to put them together, otherwise i wouldve increased the price to compensate for the labour required. it was also way easier to completly stuff the lid the old way.
im going to do other cars aswell.... but im flat out working and making boxes for gtst's after work,only so many hours in a day.
ill post up some pics of the new box shortly, it looks nothing like the photoshop job.
cheers
Linton
  • Replies 105
Posted Images
These look fantastic. Just a warning though - if a cop wants to defect you, he CAN and WILL. I have a UAS carbon box around my pod (not nearly as classy looking as this one!), and the cop that defected me a couple of weeks ago physically pryed the top up so he could see the pod underneath. I don't konw about other states, but especially in Sydney's South (where I got defected) there's a huge blitz on performance cars.
I spoke to the RTA, and the bloke on the end of the phone said "As long as it's in a box, it's fine!" - As people have said in the past (I hate bringing this up again), the law is open to interpretation.
Anyway - just be careful, and always, ALWAYS argue until you win :D
Back ON topic - if you have a pod, or are thinking of putting one on, buy one of THESE - they look very trick! Well done
Tragic, the new price is $130 or $140 delivered.
Akeevil... quite true in what you are saying... good thing about 2mm aluminium is its not easy to bend by hand, even to pry up. :)
i have been asked by a few people if i could put perspex in the lid, this will not be done as its easier to be defected, the point of the box is to conceal the pod to make it harder to be defected... even though the pod is boxed and "legal", if the cop can still see that you have a pod, he'll get you for a noise test or some other bullshit.
cheers
Linton
Hi Mate,
Looks real neat and very professional, nice stuff.
Ive got a Series 1 1997 Stagea wagon (RB25det) with aftermarket K&N pod airfilter. Will soon be adding a Hybrid front mount intercooler.
How much for one of these enclosed pod airboxes, with postage to adelaide, and do you know if it'll fit a Stagea?
Regards, Brendan
here we are guys,
the first one
showphoto.php?photo=15186&cat=500&page=1
http://www.skylinesaustralia.com/photopost...&cat=500&page=1
will be in production soon, just waiting on some more equipment to make a better more professional product.
so far only for r33 gtsts
made from 2mm polished aluminium with blue, red or yellow trims
$100 + p/h
[email protected]
cheers
Linton
cheer bro e pewhe ana koe, no whea koe
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
