Not sure if anybody would be interested but
it's worth a try anyway, i need to sell this car
as we have one too many cars at home...
Just an expression of interest of seeing if there
is any interest at all, sorry for all wanting and
looking for other cars but you guys are a bunch of
nice guys and hope you understand you need to
make some money to spend some money..
1992 Honda Legend, Burgundy, 3.0Litre 6 Cylinder 4 Speed Automatic Gold Series (Features standard Leather Interior, Sunroof, Power Windows and Mirrors, Air-Conditioning with Climate Control, Electric Seats, ‘Step-On’ Handbrake)...
Custom Genie Cat-Back
Apex-i S-AFC with Apex-i Cold Air Intake
Custom Front Lip, Full Bose Sound System (Home Theatre NOT Car Audio, Custom Install)
Engine Start Button
King Springs with Racing Suspension with Racing Gear 10 Spoke's 17''
Very well looked after vehicle, runs very nicely and turns heads easily. All mechanical work done by XSpeed and Sound System done by Audioart & Technologies and everything related to bodywork by Spoiler Shop... VERY luxurious and must be seen to be appreciated... looking at a price around $17,000
Any comments made good or bad appreciated
but please don't hack me for the price as i think
this is more than reasonable as it was worth
23k-24k a few years ago (few being 3-4)
This car is very well presented and looks a
beauty.. very very nice car!
http://tinypic.com/5p4g95 Front Left (Side)
http://tinypic.com/5p4f28 Side (Left)
http://tinypic.com/5p4jg8 Interior Picture
http://tinypic.com/5p4ck9 Rear
http://tinypic.com/67qg61 Exhaust
http://tinypic.com/67qj68 Rims
As mentioned, needs to be seen to be
appreciated!
p.s Anybody really interested can pm me i have
a few more photos i can send, i just want to
make sure i get a little bit of interest first.
Andy :O
i am looking to buy another car
and wouldn't mind a swap and
cash but i am not really into 4
door Skyline's of any sort...
sorry man, but there not for me
thanks anyways man, might
have some links up tonight as
well guys, thanks for the
interest man... :jump:
okay, would anybody want to swap cars
with cash adjustment? i am looking at a
180sx in particular but seriously can't buy
without dosh and i just want a change...
this car is automatic for starters and it's
NA as well, after feeling boost a bit too
much lately i don't think NA is me until i
can afford to get my Type-R *DrOoLZ*
are there any ricers out there that might
want to buy an NA Honda, it's better than
any Civic GLi i can assure you and you
won't get bagged on unless it's about
being automatic haha, anybody that don't
have enough time for modifying of any sort
or anybody that has no idea what they
would be doing and buy an already decent
car!
*perth people only*
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
