So Group A and N1 turbos aren't the same thing?
No, see the maps. There is a big difference.
Having said that the A/R ratios for both the compressor & turbine housings are the same as for the larger of the N1 turbos, ie 0.6 & 0.64.
I have never seen maps for he two different N1 compressor arrangements, ie 0.42 & 0.6 A/R. So I can't be 100% sure as to which compressor set up the map is for - although being an R33 N1 it is probably 0.42.
Is there anyone with any maps for any of the common Skyline turbos? If so please post em.
https://www.sau.com.au/forums/topic/76877-group-a-turbos/#findComment-1407749
Im not sure what the graph means ! How much do these turbos cost usually secondhand and what boost can they run ?
Numbes vary, but 10lb/min of airflow gives approx 100hp at the flywheel. The pressure ratio is pretty self explanatory.
For costings, take a look at the for sale section & any number of the vendors on the site.
https://www.sau.com.au/forums/topic/76877-group-a-turbos/#findComment-1407842
Hi, i have a set of group A's, i thought they were the same as N1's, but would be great if someone can correct me. Mine are quite laggy, not hitting useable until 3900ish, and they really start going after 4.
i have dynoed 260kw@all 4's so i guess that translates to about 340hp@wheels and that is at 1.2bar or 17psi. I have almost travelled 5k since the rebuild and i will be adjusting the timing and winding the boost up to 1.35/1.4bar depending on the exhaust temps? i will also be putting a larger exhaust on the car as it is only a 3 inch. When i have done this i am expecting around the 280+kw@aw
i have heard that they are practically the same as HKS 2530's as far as size, but the HKS units can handle slightly more boost and also run cooler when pushed.
If anyone has more info i would really like to know!
cheers,
Francisco
https://www.sau.com.au/forums/topic/76877-group-a-turbos/#findComment-1407947
I just picked up a pair of turbo's built to this spec. Melv's old ones. He made over 300kw at all 4, from memory he wasn't running aftermarket cams , full boost was around 4500rpm. These turbo's are a tad larger than 2530's.
Rev210,
With the group A turbos you need to be aware that the relatively low efficiency of the compressor will give you a higher inlet temperature to you intercooler - ie have a think about the cooler.
If you use 25lb/min airflow & a pressure ratio of 2 as an example the temperature at the intercooler inlet will be almost ten degrees higher when using the group A turbos than when using the N1 turbos.
Have a look at the attached graph. It is a log of temperatures from my mates RX-7 when he is giving the thing a bootfull.
Blue is at the air filter
Pink is after the turbo
yellow is after the intercooler
cyan (Aqua) is at the throttle body
Note that the cooler is a cheap chinese type, but nonetheless has an efficiency of 71%
Note also the effects of heat soak.
at the end of the run there is an idle period. Note way the air filter temps rise when the car is sitting still, eg at the start of a hillclimb. This is the downside of having pod filters with no external air feed.
https://www.sau.com.au/forums/topic/76877-group-a-turbos/#findComment-1413935
sorry to hijack BNR, i have a few more questions below??
- Do the compressor sizes differ much for group A's and are they all ball bearing?
- What sort of power are people making with their setups?
- What is the max PSI efficiency, 1.3bar?? I have a big FMIC, 120mm thick?
Cheers,
Francisco
https://www.sau.com.au/forums/topic/76877-group-a-turbos/#findComment-1413981
The Group A turbos I have seen have all been plain bearing with 360 degree thrusts. Although I can't think of any reason why you couldn't use the Group A compressor and turbine with a ball bearing core. The R34GTR N1 turbos are ball bearing as are 2530's.:D
https://www.sau.com.au/forums/topic/76877-group-a-turbos/#findComment-1414007
Cheers,
Francisco
Francisco,
There is a difference between the pressure ratio at the turbo compressor & the Manifold pressure (ie MAP) as seen by your ECU.
The pressure ratio equals (atmospheric pressure + boost) divided by the pressure at the turbo inlet.
Obviously there will be a pressure drop through the induction box (say 1 or 2 pounds) & a pumping loss across the intercooler (maybe the same again). Hence a PR of 2.5 at the turbo may be as low as 1 bar at the gauge. Hope that makes sense.
For hp, approx 10lbs/min of airflow will give you 100hp. (At the flywheel & a bit approximate). With two turbos, 30lb/s of airflow each will give 600hp. To achieve these flow rates you may then pressure ratios higher than the 2.6 which is the upper limit for the 66% efficiency island. The end result is that the inlet temp to the cooler on a warm day will be well above 100 degrees!
If, for the sake of the argument we use the following:
PR from turbo is 2.5.
Compressor Efficiency is 66%
Ambient air temp is 27 degrees.
This gives a turbo outlet temp of 133 degrees.
If we assume a 75% intercooler efficiency when then get a temperature at the throttle body of 53 degrees. However, with the addition of some heat soak into the system it is quite possible to see an air temperature into the motor of some 60 degrees. Fairly warm & it only gets worse on a hot day...
https://www.sau.com.au/forums/topic/76877-group-a-turbos/#findComment-1414019
ohhh, i understand.....thats bad. I have noticed it suffers from minor heat soak now at 1.2 bar, losing 1-2kw over various dyno runs!!
i currently have 260awkw so i guess they have quite a bit left? I will have to monitor the exhaust temp and inlet temp if i put some more boost through? I was hoping to run them on 20psi.....but i might have to check.
Do plain bearing turbo's continue to audibly spin after the engine is turned off for 15-20seconds?? I have been told that, the spinning sound is because they are ball bearing?
here are some pics of the turbo's when my engine was out
https://www.sau.com.au/forums/topic/76877-group-a-turbos/#findComment-1414172
Something to be mindful of, rather than afraid of.
Depending on the dyno, 260awkW is about 360rwhp which is conservative for A turbos.
The Group A turbos are designed for relatively high pressure ratios - just that they are not the most efficient things going around.
https://www.sau.com.au/forums/topic/76877-group-a-turbos/#findComment-1414220
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
