If you want some cheapos Chris....I run Simex sm8000 i think they are. They hold up pretty well for me in the wet and dry. I was giving em a mild test before in the wet, and they were gripping well.....easy to control the throttle to bring on the wheelspin if thats your thing :D
They are about $120 each when i got mine in January...
Toyos are a good brand though.....
https://www.sau.com.au/forums/topic/76882-toyo-tranpath-sw/#findComment-1408420
mmm, they seem cheap enough
Darren, where yours 16's? What are the sidewalls like? They will be going on the front first up, and I don't want a squirmy tyre on the front, it feels like shit if its like that
Thinking of going 205/55, but as the rims are 7.5" wide, it will stretch them out a bit and give it a bit more feedback through the wheel. I have run 205 on the front before, and to be honest, it felt better than the 225's as they had less sidewall flex, and braking was just as good. They are much cheaper too!
225's are a minimum on the back, even then grip is marginal
RaseR - what are the sidewalls like on the 17's?
https://www.sau.com.au/forums/topic/76882-toyo-tranpath-sw/#findComment-1409397
i had transpath something or other on my old car, they gripped well since the car was close to stock, so ok for the price.. a bit slippery in the wet though!
and i think they are quite soft, as mine wore out to the thread in 15000kms :P :innocent:
https://www.sau.com.au/forums/topic/76882-toyo-tranpath-sw/#findComment-1409464
I had a set of those on my car for about 3 years and never had any problems with them. Good grip on dry roads, decent grip on wet roads. Had a few hairy moments with 'moderate' take offs at traffic lights in the wet and also with a car load of people though! But definetely good for that price.
"The internet? Is that thing still around?"
https://www.sau.com.au/forums/topic/76882-toyo-tranpath-sw/#findComment-1409471
getting two on saturday, will post results
Its was either a Toyo at $165, a Falken 326 at $160, or BF Goodrich at $220
I think for the $100 saving over the BF's, they are worth a shot. If they have soft sidewalls, I'll just run them on the back!
https://www.sau.com.au/forums/topic/76882-toyo-tranpath-sw/#findComment-1409824
Hey Chris,The sidewalls on the Toyo TSW have more curvature then my previous Kumhos which were squarer (note, I have 8" wide rims on 235s and run 32psi). They still seem to be relatively stiff though, with no more noticable flex then previously - I'm only running them on the rear though.
https://www.sau.com.au/forums/topic/76882-toyo-tranpath-sw/#findComment-1409850
Yeah, my size is 225/50/16 all round. My front rims are 7.5" wide also. Dont really know if you can call em squirmy or not...they do me just fine in the dry or wet. I run them front and back. My last tyres were 205's on the front, and they feel the same as these 225's on now.
Agree 225's are minimal for the back.
I guess how much you spend depends on how hard you want to push your car then, eh Chris? :)
https://www.sau.com.au/forums/topic/76882-toyo-tranpath-sw/#findComment-1410475
Well, first impressions are very good
Only done about 300kms on them, all wet, and they are very good. Will post up results as they get a few kms on them.
Extremely quiet at highway speeds
Pretty happy, decent sidewall too, so they handle well up front
Chris
https://www.sau.com.au/forums/topic/76882-toyo-tranpath-sw/#findComment-1418389
Yeah, got the Toyo's
Went just for a front set, I hate buying a full set of tyres I have never tried before!
I want some dry weather dammit!! They seem really good so far, dry tests will be the key once they have a few kms on them
They seem to be a reasonably hard compound too, so should get a few kms out of them. Once they are scrubbed in a bit I will throw them on the back and see if they are worth getting for the rear. If they are I might get a set of Toyo Trampio's for the front, they look to be a really good tyre for the front
Will post up results!
Hows the 3L in the wet? Would be a bit of fun wouldn't it! I remember going for a lap around the block in the dry and it was pretty taily with the mech. diff in it. Mine is and it has half the torque lol!!
https://www.sau.com.au/forums/topic/76882-toyo-tranpath-sw/#findComment-1418852
Very interesting in the wet...your able to keep the revs down and still get some tractions...just putt away and let the torque pull :P Mechanical diff hepls traction though..much safer i think than my old viscous diff...
IF you like wet weather well....its damn fun and scary at times :rofl:
https://www.sau.com.au/forums/topic/76882-toyo-tranpath-sw/#findComment-1419413
  • 4 weeks later...
Well, about a month on these now, quite impressed!
Easily the best value tyre I have had on my car, getting a set on the rear in a few weeks.
Feel much better than the FM901's they replaced, very quiet too!
https://www.sau.com.au/forums/topic/76882-toyo-tranpath-sw/#findComment-1463381
    • What Duncan said sounds right. Also, it looks like they only have the driver's mat. Not the rest. Because looking at the diagram: KG4911 is just the mat for the driver. KG4900 is the full set if I'm not mistaken and discontinued.   But, it looks like they may still have the full set for the manual S2. Might be worth checking for the other models as well as they seem slightly different. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/misc/G49 Man, I'm tempted.
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
