Hi guys,
I've got an r32 gtr with the above turbo setup, i've searched the forum for other peoples experience & cannot find the answer i am looking for...
Are there any 'other' gtr owners out there with this setup? I am after an approx. awkw rating.
I have read 3 other posts specific to this turbo but it seems that nobody has really given these turbines a genuine run due to their lack in bottom end boost.
Im sure the top end delivery would most definitely suffice :D
Thanks,
Marko.
p.s. where did my post disappear to???
"Bel Performance v's Croydon Racing Development - which 1?"
it was so informative :P everyone had something to say.
message Mik He's got the same setup as you but in a 33 . I thaught your car had already been tuned by CRD as you said in one of your posts that you were going with them?. My guess with your setup would have to be something close to 400awkw on CRD's dyno but I wouldn't get to involved in dyno numbers get it out to wsid and test it on a real dyno :D.
My car was scheduled for a tune last week but im sure you all know how these modifications pan out - odd hurdle, hick up here & there.
It will be dyno tuned later this week, just awaiting the arrival of my 3.5 inch exhaust which is due tomorrow.
Brett - I have spoken to 'Mik' before about this but I know that he has undergone a road tune, I'm very interested to see what they will produce on a dyno.
Is there anyone that has hands on experience with power delivery?
Regards,
Marko.
Miks car has been on dyno log dyno which is very very low reading compared to something like a dyno dynamics .From memory I think at the end it was something around the 280awkw mark but I believe they later learned after puting another car on that dyno on the same day it was actually reading lower then usual the result should have been something along the lines of the 310-320awkw mark but I'll the man himself step in and correct me .
After seeing the peak power dyno results from a couple of CRD GTR's and there times out at wsid I'd say his car would be pretty damn close to 400awkw on a dyno dynamics.
this dyno sheet you have, is this rwhp or awhp?
rwhp
note also the terb shuffle during boost build-up. I have since gone to a bridged HKS manifold that should reduce this effect markedly. I will also be expecting 550 or better rwhp with more boost and timing.
My car was road tuned and had the tope end "touched up" on a dyno log as Brett pointed out.
The max power we saw was 292 awkw. This was at a fairly rich 11.6:1 AFR and pretty sane boost.
Two weeks later, a certain WRX made 230kw on this dyno and then made 290kw on a dyno dynamics the next day.
I guess that gives me about 360awkw on a dyno dynamics which alogns well with my 124-125mph trap speed in a heavy BCNR33 Series 3.
Gav, mine makes about the same power as yours.
i have twin hks 2835's 52t
on the dyno we ran 1.3bar but took it back to 1.2bar because im still running cast pistons and the injectors are maxing out. the next step is going to cost a fair wack :) unless someone is selling a rb26 with fogies etc
it would also depend on how heavy your right foot is...anything will blow in the wrong hands, in the right hands it will last.
jim @ crd mentioned that up to 22psi is safe & that quite a few guys also run 25psi, usually if they want to run a 1/4 mile.
anymore than 25psi would be really pushing it i think
Marko.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
