Hylomar aero grade gasket joining compound RRP Price (AUD): $50.00
Non hardening and non setting. Unlimited assembly time. Vibration resistant. Allows metal to metal contact. Resistant to combustion products, water, engine coolant, petroleum, lubricating oils, kerosene and fluorocarbon refrigerants. Seals surface imperfections. Withstands rapid variations in temperature. Flame, dust and moisture proofing properties 100gm Water and oil pumps, instrument inspection covers, cylinder heads and sumps. Coating pre-formed gaskets, weatherproofing motors and outdoor high voltage circult breakers. Inlet manifolds, timing case covers, oil pump joints, gearbox and transmission components, thread sealing. Gas turbines, water cooled generator, turbo vacum systems and any machined surface.
they come in 100g tubes like a big tube of tooth paste i purchaced a box in from a mate in england. i am selling fifteen tubes may be more depends on how much i use he he @ $15 free postage this stuff is definatly top of the line thats a clear huge saving
price drop price drop
https://www.sau.com.au/forums/topic/77277-aero-grade-gasket-joining-compound/
  • Replies 44
sorry dude these tubes are $15.00 deliverd RRP is $50.00 check it out if you don't believe me there is only a couple of places that distribute it in aus, and it's for that price of $50.00
so $15.00 is a dead set bargan
the stuff you buy for $13.92 at super crap is shit if you want to buy that go ahead it it will just let you down in the long run.
Haha I meant are you willing to sell me one tube for $13.92? Reason being thats exactly what I've only got left in my account. Don't get payed until next thursday and don't really feel like going out to the bank just to deposit $1.08 LOL.
inasnt yes metal to metal seals are the best for this compound i have done my rocker covers and have had no leaks at all
sorry ongsta it would be unfair for other people who have purchased from me at $15 a tube
isnt this the same as loctite #3 (or otherwise known as aviation cement)
loctite #3 is way cheaper and comes with a brush applicator
used on my rear main and on plenum no leaks
definatly not this stuff has an unlimited assembly time loctite has a hour set time pain in the arse for when you lost a bolt or something also having a set time reduces its life span
this stuff is approved by and meets rolls royce (spelling) stringent tests it is also approved for use in all defence airforces around the world definatly top of the line
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
