New or Used Rims from the Auction
To search for wheels, click:
http://www.bt-revolution.com/Wheel%20Page.htm
For estimated price, click:
http://www.bt-revolution.com/Landed%20Rim%20Price.htm
Rules/Agreement to bid/buy:
1) You tell us your max landed price (For Auction Item)
- Some deposit is required before bidding
2) Full refind will be given if the auction is unsuccessful
3) When the auction is completed (won) and you change your mind, the refund will not be given.
4) If you are unsure of anything, please feel free to ask us
5) No responsible/claim for used parts
**Please provide; size, stud patterns, brand and model**
RAYS CE28
- 17x7.5 +43
RAYS GT-N
- 17 +35offset
TE37 - GTR Offset
- 18x9.5" +12 offset
WORK VS-KF
- 18x8.0" +38
- Good Thread
- Auction Ending soon, could be relisted
WORK Euroline KH 19"
- 19x8.0" +40
WORK-VS DISH
- 18x9.5 F +31
- 18x11.5 R +19
Another WORK VS DISH
- 18x9.0" +32 offset
- 18x10.0" +32 offset
TE37 - MINT
- 17x9.0" +22
Minimum $2900.00 landed
Ends 18 June
Will list more wheels as request soon.
Fullo - can't really say exactly how much we charge, there are many cost involves as follow:
- Commission to our supplier
- Japanese tax
- Bank fee
- Inland shipping (Normally 6000 yen)
- Shipping to Melbourne (sea)
- Tax and duty
Once the shipment leaves Japan, it takes 25 days + clearing at the custom, etc
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
